Suspension Noise
Old Jul 19, 2008 | 12:13 AM
s4avt's Avatar
'03 CLK 55
Suspension Noise
pretty often, when i hit the bump or make a sharp turn, I hear kind of squeaking suspension noise comming from passanger front and rear side.
Anyone experienced similar situation? could be bad shock? or pads?
so I was thinking if I get KW V2, it might fix it...
what do you guys think?
Old Jul 19, 2008 | 02:36 AM
OLDSCHOOLRICE's Avatar
07' E350, 71' DATSUN 510
Squeaking is usually ball joints and sometimes swaybar bushings. Not likely a shock/strut or spring. Bad shocks/struts usually make a clunking or rattling noise.
But I do think that after you repair the noise, you should still get the KW's!!
Old Jul 19, 2008 | 03:01 AM
Eurosport's Avatar
monowiper
+1
could be ball joints, tie rod ends, stabilizer links, swaybar bushings...lift it up take a look at their condition
Old Jul 19, 2008 | 10:33 AM
s4avt's Avatar
'03 CLK 55
thanks guys!
Old Jul 20, 2008 | 09:05 PM
AMG10's Avatar
noise
I had this on my wife's c240 jacked it up and put some lub on the swaybar bushings. That was it.
