scrapping sound when making left turn
Old Sep 7, 2008 | 01:24 PM
ac_schnauzer's Avatar
everytime i make a left turn i hear a scrapping sound - almost like the brake dust shield is touching the brake disc. after pulling the wheel off and examining the wheel assembly i am not able to determine what's causing the sound.
my bmw used to do the same thing and it is really annoying.
anyone have experience with this and know what's causing the noise?
Old Sep 9, 2008 | 08:59 PM
da_guitarist's Avatar
Current: AMG GT-C. Sold: 01 CLK55, 00 ML55, 01 ML55, 06 E55
not fender rubbing?
Old Sep 10, 2008 | 12:07 PM
AMGOODNESS's Avatar
03 CLK 55 AMG, IMCO muffler/Magnaflow tips, KW V1 coilovers, 19" Petrol Metrix Wheels
i posted a couple of weeks back about my right rear emergency brake coming loose and rubbing on the hub. a spring came loose that holds the assembly together. it was a constant noise though.
Old Sep 10, 2008 | 07:05 PM
Originally Posted by da_guitarist
not fender rubbing?
i don't think so. it used to make the noise even when i had stock ride height and wheels
Old Sep 10, 2008 | 07:08 PM
its only when i make a left hand turn and sounds like its coming from the front passenger side.
i might have to make a trip to the dealership...
Old Sep 23, 2008 | 08:58 PM
fourml8r's Avatar
2005 CLK55 AMG CABRIOLET
i have the same problem. took it in for service and they adjusted the clearance between the brake and the hub. it helped but not 100%. i'm taking it back next week to see if they can adjust it better.
it only happens when making left turns and is coming from the front passenger tire area.
Old Oct 1, 2008 | 11:53 PM
cleanslate's Avatar
W208 CLK55
Does it happen in reverse too? I wonder if part of your plastic fender shield/guard is loose, something like that happened to me and it rubbed even when I had my stock wheels on.
Old Oct 8, 2008 | 10:10 PM
fourml8r's Avatar
3rd repair for scraping sound
here is how all 3 repair attempts have gone so far:
1. tightened up wheel well plastic shrouding - did nothing
2. adjusted clearance between brake and wheel hub - helped a little bit
3. tightended torsion bar - seems to have corrected the problem.
the scraping sound in my car was present in both forward and reverse.
Old Feb 26, 2012 | 10:52 AM
landen's Avatar
C230
I have an issue with my left front tire, everytime I make a sharp right turn it is rubbing on the wheelwell.
I jump a curb going pretty fast a few days ago and ever since then I have been having this problem.......what is it?
