CLK55 questions
Old Sep 9, 2008 | 03:33 PM
johnnytang24's Avatar
2001 CLK55
CLK55 questions
Hi,
I recently bought a 01 CLK55. I have a couple questions I hope someone can answer for me.
1) I read that the tranmission fluid should be changed every 50000 miles. About how much does this process run? $100? $1000? $10000? Will any Mercedes mechanic be able to do this for me, or will I need to find some specialist?
2) I was thinking of getting some Goodyear Eagle F1 GS-D3 tires. I only drive on the road. Are these a good choice, or do you have any recommendations? Should I stick with the 225/45R17,245/40R17, or can I get something like 225/45R17,245/35R17 (they don'tmake any smaller front tires)?
3) Does anyone know of a reputable Mercedes mechanic in the Pittsburgh area?
Thanks.
Old Sep 9, 2008 | 04:27 PM
AMGOODNESS's Avatar
03 CLK 55 AMG, IMCO muffler/Magnaflow tips, KW V1 coilovers, 19" Petrol Metrix Wheels
i would check the aspect ratio on those rears first. do a search on tire calculators and you will see what i mean. you dont want them spinning too fast or too slow. you car will not be happy.
Old Sep 9, 2008 | 04:43 PM
ashutt's Avatar
2005 SL600 by SPEEDRIVEN
You comment that you only drive on the road is somewhat odd? What other options where you considering- the track (if so consider an R-compound tire).
I have the F1 DS-D3 tires and they are excellent, especially in the rain. Another top choice is the Michilin PS2. As for the aspect ratio, you will want to go 5%lower in the rear. For example, my car has 235/35 up front and 265/30 in the rear.
Also, I don't believe you will find 245/35 profile tires as the 35 aspect ratio is for 18' rims and above. You could do 235/45 in the front and 255/40 in the rear on your stock 17" rims. Try tirerack.com. Good luck.
Old Sep 10, 2008 | 12:09 PM
AMGOODNESS's Avatar
good advice ashutt.
Old Sep 11, 2008 | 06:14 AM
2001 CLK55
Thanks for your advice. I'm sorry, I don't know much about tires. 235 and 255 will fit on rims made for 225, 245?
Old Sep 11, 2008 | 01:55 PM
ashutt's Avatar
When you buy your tires just check with the sales rep on the 235 and 255 for your rims. Luke at Tirerack is a good source of information and help. He will hook you up with the proper set of tires for your rims.
Old Sep 14, 2008 | 04:29 AM
DesertMotorWork's Avatar
CLK55 AMG
Thanks.
Contact Foreign Fix. http://foreignfix.com/
