First Benz purchase ?? Info needed plz.
I'd like to know what I can expect from this model: items or systems that seem to fail at predictable intervals i.e. fuel pumps, brake system components other than the obvious pads and rotors; common items or system problems over all such as keyless ignition problems, sensors, displays, etc., fuel mileage?
Any help would be greatly appreciated.
The normal wear stuff to watch for at this stage will include:
- Power seat motors
- Both motor mounts
- Trans mount
- Brake light switch
- Possibly the differential side seals
- Flex dics
- Possibly the catalytic converters
Has anyone had this problem? How can you tell if this has happened to a particular vehicle? Is there trans fluid present in the coolant or vice-versa? Has anyone just simply installed an auxilary trans cooler and by-passed the in-radiator cooler? How much is a relacement trans for these cars?
I know, I know, alot of questions, but I'd like to make sure about this vehicle. The more I look at pictures of it, the more I fall in love with the styling.
Good luck, you will love the car!!
