CLK 55 Tire Pressure
Old Jan 15, 2003 | 12:23 PM
John Failla's Avatar
2001 CLK55 AMG
What is the optimal tire pressure to ensure best handling, reduced understeer, and strong turn-in on a 2001 CLK 55 with the standard 17 inch AMG wheels and Michelin Pilot Sports and no suspension mods? Thanks
Old Jan 16, 2003 | 12:57 AM
karl k's Avatar
2002 CLK 55 AMG Coupe ;)
Welcome!!
For EVEN tire wear - new tires: 38F/35R
You get UNEVEN wear if you follow the pressures listed on the gas filler door: 33/33
Fortunately, I realized the erroneous pressures after 8,000 and made corrective pressure adjustments.
Old Feb 6, 2003 | 02:34 PM
Pat in NJ's Avatar
CLK 55 AMG Cabriolet
Pressure on Gas Filler Door
Originally posted by karl k
Welcome!!
Karl K:
My 2002 CLK55 AMG Cabriolet gas filler door does not specify the 33/33 pressure that you noted. Would the 38F/38R pressure be appropriate for my car with 17 " Michelin Pilot Sports 225/45 in the front and 245/40 in the rear?
Thanks in advance for your help.
Old Feb 6, 2003 | 05:42 PM
karl k's Avatar
Re: Pressure on Gas Filler Door
Originally posted by Pat in NJ
Karl K:
Pat -
perhaps the gas door info was changed or is different at the cab, which is I believe 200 lbs. heavier. Mine has info overload label, made for the nuclear physicist.
Since you have the standard tires, I assume that you do average driving: half highway & half city.
Then I would go with 38 front & 35 rear. I check my presures once a month.
PS:
nice footer/signature
Old Feb 6, 2003 | 11:38 PM
Pat in NJ's Avatar
Smile
Karl K:
Thanks for the info. Seems there are alot of us with suspiciously similar footer signatures.
Thanks again.
Pat
Old Feb 7, 2003 | 12:45 AM
karl k's Avatar
Karl K:
Thanks again.
Pat
That;s for sure Pat. I am trying different designs for a new one.
