Can you help me play with my new CLK55 AMG?
I totally love it, although I really was looking for something...well, sportier, and "snarlier," I couldn't pass it up after I drove one. There wasn't much else out there I was very interested in, and it's obviously a really awesome car.
Anyway, I hate something really bad about this car: ESP. And it's not like you can just turn it off. It turns itself back on...
After I turn it off the second time, it usually stays off for at least 20 or 30 minutes, maybe more - I haven't really taken it on a truly long drive yet.Is there a way to either make the default position off? I've read a few posts here about "dyno mode." I really don't want to disable ABS, but what the H - I lived without it all those years just fine anyways. Could you tell me more about the toggle switch I've seen at least one post about? Installing a toggle to switch the damn thing off? Can you do this without adversely affecting the other functions of the computer?
Also, I would like to tease the last few HP out of the beast that are available. Any advice about which performance chip to get, maybe other "easy" mods that will put it nearer 400HP or + + +
I have to be careful that anything I do is either not visible, or easily reversed - as the factory warranty was out, and to get a really good extended/aftermarket warranty out to 5 yrs and 100k miles, I had to spend $5k, and it very specifically excludes much significant coverage in case of mechanical failure if there are performance mods. Should I get another "black box" to hide the evidence, as a switchout in case I throw a rod? I presume the ECU upgrade and such goes into this black box (mind you, i know nothing about this car. I've had it for a couple of weeks, and I'm a total newbie. I've been playing with Porsche 928's for a few years, but prior to this, my last gearhead experiences were with Mustangs and a Barracuda many years ago)
It looks like many of you use Kleeman; I suppose they must be the gold standard go-to. I am willing to spend some bucks, but not many, many thousands. What would you all suggest?
Thanks in advance for all of your help.
Clay
As far as mods go good luck there without spending big $$$. Chips on N/A cars don't do a whole heck of a lot and you will likely need some kind of FI to make big power (kleeman, Renntech etc.) and your are looking at 10k + to get there.
I decided to buy a 996TT to mod and play with and keep my 55 stock since the mod path on these is so much cheaper.
Also you cannot fully bypass the tcs functions on the car, I read about dyno mode too but heard that your car will just sit and spin with it engaged (search for it). Also I will be in STL this week for some work so PM me if your around as I would love to see the ride.
Good luck whatever path you head down....
Aieee, this thing is only getting worse. Took the thing to JiffyLube the other day for an oil change, bringing my 2 quarts of Lucas oil additive (I'm a big believer in it, especially with this watery oil they spec for cars these days, 5w30). Nice car, they say, I came in with my own filter, and we do the deed: but, oh-oh, damn...can't find the dipstick...WHERE can it be...they can't find it, I can't find it, finally they call someone, and it turns out there IS NO dipstick. "Oil changing is a factory-only service" is the explanation. "Don't worry, as long as you put in the 9 quarts specified, it'll be OK."
I want a dipstick....
That damn thing that looks like a trannyfluid dipstick housing doesn't have a dipstick in it, either. "Factory-only servicable fluids," I'm told...
I hate this a lot. Really love the car, but I don't know if I can hang with this. I guess the factory guys must use a special dipstick tool that you buy, or something? (The jiffylube dudes say I have a seep down there from the tranny)
Yikes.
9 qts of $5-7 Mobil 1 = min $50, up to $65 depending on the hook up. Oil filter = $10 min.
Post up some pics of that beast too.
Do you have an owners manual?
Mine is in the car, covered in my garage, so I don't have it in front of me for reference, but I'm sure that there is a chapter devoted to the speedo mounted display.
Read about the oil level check function.
No dipstick is necessary as MBZ has determined that the computer is capable of doing the job for you.
Believe it or not, many MBZ owners don't look under the hood, and won't dirty their hands checking or changing oil.
