Help needed power seat removal 2002 CKL 55
Subscribe
Feb 14, 2009 | 04:46 PM
Hoping anyone out there can help me. Drivers seat motor (the one which moves seat backward & forward other motors ok) is dead. I need to get the seat removed to replace the motor. Problem is the seat is so far forward I cannot access the 2 front Torx bolts to remove the seat track. Rear ones no problem. Is there a release on the motor or a way to manually move the seat back? If I could bet it back about 1 1/2 inches, I would be home free. Any help would be greatly appreciated. Chuck in Atlanta
Reply 0
Feb 15, 2009 | 12:43 PM
Did you check the fuse it might be just that...when mine was giving out on the passenger side it kept on burning the fuse about 2 times a week but it was still working...hope this helps...
Reply 0
Feb 15, 2009 | 04:11 PM
i'm having the same problem
Reply 0
Feb 25, 2009 | 03:23 AM
you have to remove the seat torque screws on the side and lift the seat cushion, i also recommend you remove the computer with all the wires attached to it to give yourself more room
Reply 0
Subscribe
Currently Active Users (1)
