New Tires, went the cheap route
Also any other W209 owners out there with issues with the front tires wearing out on the outer edge?
BTW, I was a restaurant (small hole in the wall Japanese) and the UPS guy came in and delivered some aggressive tires while I was having lunch. I asked the owner what he drove and he said C63 AMG; he only get's 4,000 miles per rear set!
Thread wear IIRC is around 220's. Super quiet and very grippy. I would buy the same ones for my second set once i'm done.
Vid of the burnout pls.
If you are wearing out the outside edges of your front tires, you have too much "posative" camber.
Conversly, when the inside edge wears out you have too much "negative" camber.
When you view the tires from the front or rear of the vehicle, the tilt inward or outward relative to the road surface is called "CAMBER".
It is expressed in degrees "posative" or "negative".
Leaning OUT at the top is "posative" camber, leaning IN at the top is "negative" camber.
Incorrect wheel camber will result in premature tire wear and excessive wear on the suspension parts.
Over inflation wears out the centers, under inflation wears out both outer edges simultaniously.
TOE, is a measure of how much the wheels are aimed in or out from a straight forward position. This is done to make sure the tires roll parallel.
When the wheels are turned in, toe is "posative". When the wheels are turned out, the toe is "negative". Some people misspell it "TOW", but it is "TOE".Toe adjustment also serves to counter small deflections in the suspension system that occur when in motion.
Incorrect toe adjustment will result in premature tire wear and improper steering stability.
I suggest that you take the car to an alignment shop and get a four wheel alignment accomplished.
If you don't, why would you think that your new tires would not wear out on the inside edges just like the last set did? They will, so dont blame the tires. It is caused by incorrect alignment, and you will be replacing these new hides shortly.
This is very basic stuff, and can be accomplished by a competent shop in less about an hour.
Tire inflation pressures shoud be set at the manufacturers specifications as well.
Obviously, the tires should wear out evenly across the tread surface.
They cannot, unless the suspension and pressures are adjusted to factory specs.
I have an old 1989 300E for a daily beater, along with my Beast. When my Michelin MXV4+'s went to tire heaven I went your route and bought the Generals.
Big mistake.
Immediately afterwards I noticed a strong front end vibration at speed that was never present with the Michelins. At 80-85+ I could actually see the entire hood vibrate!
I went to the tire installer and told him, we went out on the freeway and he saw (and heard) it for himself. Took it back, jacked it up, said "Your front-end suspension is shot, all the arms have loose joints" (or somesuch). So I replaced all those bits (control arms, etc.). That made it better but it was still there - anything above 73-75 or so, back came the vibration.
Because the car was realigned after the suspension bits were changed, I thought I should have the Generals rebalanced. So I did.
That helped the front hood shake a little - only to be replaced by bad vibration in the steering wheel at anything above 60. Whereas before I could avoid the whole problem by driving at 73 or below, now I have to deal with the vibrating steering wheel at any freeway speed! I just traded one problem for another
I don't know how to fix this, but all I know is that I made a big mistake not getting another set of MXV4's for that car.
I sure as heck wouldn't get Generals for my Beast.
That issue is exactly what brought me here and to your post - I just took my Beast in today (2002, 11,000+ miles) for a regular lube, oil & filter and the dealer service guy pointed out that my tires all had fine cracks on the sidewall at the curvature point. At 11,000 miles! The car is garaged all the time, covered all the time, never driven in rain ... yet the tires are cracking?
So now I'm wondering whether to replace them with more Continentals or if there is something better. I am perusing Tire Rack as we speak ...
As far as tires you can't go wrong with these Michelins, Pirellis, Bridgestone, Toyos and Kumhos.
I am considering the Michelin P2's for the CLK 55 when I have money to change the tires - but I'm still in shock that tires with only 11,000+ miles on them are ready to go to tire heaven ... especially since the car is garaged and covered all the time when it is not being used ... I guess that's what 7 years of exposure to smoggy LA air will do, no matter what!
