04 CLK55 starting problem!!
Hi everyone!! My 04 CLK55 has check engine light on, and won't start normally, fault code said it's a problem with Camshaft position sensor, anyone know where is it located and how to replace it??
07' IS 350, 08' E550
Thank you for reply MARTYMAR. Yes, the code is P0341. My car is cranking everytime i try to start it. Normally, It will take me about 3-4 times (turn key on and off) to start the engine when it is cold. With warm engine, it's random, sometimes only take once to start engine up, sometimes 3-4 times.
Thank you for reply MARTYMAR. Yes, the code is P0341. My car is cranking everytime i try to start it. Normally, It will take me about 3-4 times (turn key on and off) to start the engine when it is cold. With warm engine, it's random, sometimes only take once to start engine up, sometimes 3-4 times. ![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
2000 CLK430
The camshaft sensors are usually placed in a cool area where it doesn't get hot...these sensors very seldom go bad because of the way they're positioned to keep them cool...I'm not completely sure where they're located on our cars but I'll check with my mechanic tomorrow. Hopefully some more members would have chimed in by then with an answer or atleast more advice. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Greg
