Light-weight pulley
1 Post
'00 Mercedes 430/55 clk cabriolet
Light-weight pulley
Hi Guys!
I need a descison made on getting a light-weight crank pulley.
My radiator leaks and I'm having it replaced so I thought at the same time to change the pulley.
I want the car to accellerate a bit quicker and so thought the lightend mass should do it. How ever I read bad things about pulleys and so I'm undecided.
I know I won't make more power, I'm after accelleration.
What do you guys think? Please help!
2015.5 Volvo V60 Polestar
Hi Guys!
What do you guys think? Please help!![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
However, I also read on here that someone used the same pulley and they removed it after it started to wobble.
I too saw the you tube video of the bad 'high performance' pulley.
I recommend you do a fair amount of research before pulling the trigger. I've gone the other route and put ultra light flywheels on cars (obviously not the CLK), and the results have been positive. Lightening the rotating mass allows the engine to accelerate/decelerate faster, HOWEVER - some people have lightened the pulley by removing the damper. Without going into a long discourse (although I'm halfway there already), you NEED a damper. As long as you're pulling the radiator, you might want to consider removing the mechanical fan and replacing it with an electric puller fan. I've built a few kits for this. It's not very difficult.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
1 Post
Thanks Guys!
I'm still looking into the Pulley (probably going to go with AMS).
Marcus. My fan makes alot of noise when working, but I was told this is normal and to not worry about it until it gives up the ghost. What's the deal with the electrical one. Can I get it in the UK?
Thanks Guys!
bad, car, clk, fans, jegs, lights, lightweight, mass, mechanical, pulley, pulleys, rotational, uk, underdrive, video
