CLK-63 Black Series Steerling Wheel
Old Sep 17, 2010 | 01:34 PM
Rashman's Avatar
Mercedes-Benz CLK63 AMG Coupe
Originally Posted by FatTony001
I LIKE !
Heehee..
Well... just seemed the logical thing to do.
lol
Old Jun 14, 2011 | 05:58 PM
hami's Avatar
CLK55 '05 CLK320 '02
Originally Posted by mikare
I got one of that steering wheel too. I really love it
how was the swap like? is it a lot of work or just a quick fix?
im thinking of getting one but heard i would have to deal with airbag problems
Old Jun 16, 2011 | 09:20 AM
alingdionesiya's Avatar
honda city
What other cars would this work with then?
Old Jun 16, 2011 | 09:54 AM
Rashman's Avatar
The CLK steering wheels will also work in a CLS.
Not sure about any other of the models though.
Old Jun 16, 2011 | 01:31 PM
hami's Avatar
is the swap easy for a regular CLK?
Old Jun 16, 2011 | 01:46 PM
Rashman's Avatar
Yes, very easy.
The front cover of the steering wheel is removed along with the air bag.
Inside, you will see the wire connections for the steering wheel buttons and paddles.
Disconnect these and unbolt the steering via the big bolt right in the middle.
Put the new steering wheel in place and do the big bolt up in the middle.
Connect the wires up and put the fornt cover of the steering wheel along with air bag in place.
You transfer the steering wheel cover and air bag from your old wheel to the new steering wheel.
I did not do the swap myself, but watched as my guy at Mercedes did it.
Took about 10 minutes.
When you remove the cover from your existing wheel and remove the air bag, you will notice that the steering wheel is slotted onto a cog with lots of small teeth.
The top "tooth" will have a mark on it, presumably to identify the central postion.
Put the steering wheel in the dead-straight position before removing it.
Take note of which tooth is directly at the top, for when you install your new wheel.
I say this because my old wheel was actually located on the cog one tooth off from the marked tooth.
Install the new wheel on the cog in the same postion as your old wheel.
Old Jun 16, 2011 | 02:29 PM
  #32
hami's Avatar
sweet thx for the info
Old Jun 16, 2011 | 03:14 PM
  #33
Rashman's Avatar
No worries.
Old Jun 17, 2011 | 06:36 PM
  #34
jazzj's Avatar
clk55 AMG 04
swap out for regular clk55 AMG 03
My understanding is that retro fitting to a CLK w209 late '03 model would be a lot of mucking around, can anyone confirm this please? Thanks
Old Jun 17, 2011 | 06:52 PM
  #35
Stiggs's Avatar
2003 CLK55
Did you read post #3 ?
the airbag doesn't fit! I would have been all over this mod if I could use the original airbag.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
