Whats the widest rear wheels you have seen on CLK55
Subscribe
Aug 22, 2009 | 02:03 PM
Hi I want to put some rear wheels with a big lip. Without using wheel spacers. Whats the widest rear wheels you have put on a 2003 and up CLK 55. Pics would help too.
Reply 0
Aug 22, 2009 | 05:15 PM
you can easily run 9.5's which can handle up to a 275 tire so there isn't really any need to go bigger than that. You may need a 5-10mm spacer depending on the offset of the wheel, however the clearance on the inside is tight so spacers are recommended.
Reply 0
Aug 22, 2009 | 08:40 PM
I run 11x18 rear wheels on y 55amg w209 with 265/30 0r 255/35
Reply 0
Aug 23, 2009 | 12:07 AM
Quote: I run 11x18 rear wheels on y 55amg w209 with 265/30 0r 255/35
You Euro boys do things alittle differently though, super stretched tires is signature Germany . Although really, the widest wheels you really need to run are limited by tire size, and the widest tires you can typically run without rubbing is 275, so really anything over 9.5-10" is a bit overkill.
Reply 0
Aug 23, 2009 | 11:31 PM
Can you post some pictures?
Reply 0
Aug 24, 2009 | 03:43 PM
sure thing. Ill take some photos tomorrow. and post them here
Reply 0
Aug 24, 2009 | 06:52 PM
i run 19x9.5 with a 20mm offset. tires are 255/30/19. i am sitting really low and the wheels are flush. i am sure you could run wider wheels but you would have to get the offset perfect or you would rub on the outside fender. i not using any spacers.
Reply 0
Subscribe
Currently Active Users (1)
