Time to get new rotor and pads
Well, If you're into modding your car like most of us, then you'll go with the aftermarket pads and rotors which will cost you more money. If you stick with the OEM you'll be fine as they're very good especially for your daily commute on the streets. However, if you plan to track your car then you might want to upgrade the stock. Hope that helps a bit...just my 2 cents. anyway,, so if I decided to go with Aftermarket, which brand or which one do you guys recommend?
and How much should I expect for a break job for the front only
https://mbworld.org/forums/w211-amg/...questions.html
Andy
I went with "EBC Red Stuff".
Good brake: as good or more VS OEM
Dust: less! but still some
Noise: ... still had almost the same noise for 1 month ! but now there quite
for a total of 9/10 points for me
Akebonobekoblababllba don't remember the name, alot of members use it
I didn't because they do not do 6 pistons pads for my front
Anyway good luck
Anyway good luck
Andy
