Headlights Flickering
Old Sep 30, 2009 | 12:56 PM
wido78's Avatar
2003 CLK55 AMG
I have a 2003 CLK55 that recently developed an issue with the interior and exterior (headlights) flickering. It is almost like the alternator isn't keeping up with the power requirements. There also seems to be a small whine (RPM sensitive) that I don't remember having prior to the issue.
In an attempt to diag the issue, I checked the battery voltage (power off) and got 12.5V and then again with the engine running and it was between 14.3 - 14.5V. It just seems like it would be something with the alternator, but with those test results, I am thinking it might be something else?
After reading another post (from 2006) on another site someone was suggesting it might be a problem with the stock CD changer?
http://www.benzworld.org/forums/w210...lickering.html
Any thoughts?
Old Oct 4, 2009 | 05:55 PM
wido78's Avatar
2003 CLK55 AMG
Problem Solved...
Cost: $405
Resolution: Voltage regulator
Old Oct 18, 2009 | 01:12 AM
MeliDwhiteAMG's Avatar
CLS550 HRE 948R - CLK55 AMG Sold
Just had the dealer fix my driver headlight last week, not sure what they replaced.
Old Oct 28, 2009 | 02:17 AM
edwardmash's Avatar
esteem
i think the headlight flickering may be caused by a intermittent low voltage output from engine vibrations. when this occurs, a voltage spike causes the voltage regulator to reset.
Old Oct 28, 2009 | 03:32 PM
MarcusF's Avatar
2002 CLK430
Voltage regulators that intermittently flow low voltage due to engine vibrations, may be busted/worn out. $25 and 90 minutes can fix that problem. For those who can change the regulator without removing the alternator, make that 15 minutes.
