What parts need to be pulled from the donor engine for the swap?
This is what I have so far: s/c assy, belts, pulleys, valve springs, brackets, cams, air boxes, air box tubing, water pump, all hoses.
Does the engine have a front cover or do all the brackets just bolt to the block?
Do I need the e55 radiator for the extra heat or will the clk 55 rad work?
Anything else?? Help me out.
also need fuel rail and injectors im sure.
Currently Active Users (1)
