what are the widest spacers you guys are running?
Old May 25, 2011 | 04:29 PM
781m113's Avatar
2003 CLK 55 AMG
what are the widest spacers you guys are running? i wanna see those flushed out wheelssssss. does anyone know the largest width you can go to without rubbing the fenders? or have those of you with the flush *** wheels rolled your fenders..?
i have an 03 clk 55. i just got a set of SL55 rims (18x8.5 ET30, 18x9.5 ET33) and i wanna flush them the F out. i think the widest spacer i saw was a 25mm. is that too much for the rear? right now im thinking H & R lowering springs, 10-15 (depending on how far i can go without rubbing) mm spacers in the front and 25 mm spacers in the rear.
is 25 too much..?
Old May 25, 2011 | 05:02 PM
MTLdude's Avatar
2005 CLK 55 AMG
I'm running 20mm in the back and moving from 5mm to 12mm in front.
I had to file some extra material from the rear bumber though. I think that about the widest you can go without rolling. in the back at least.
I like the front to be more inside with the stock wheels it looks better to me.
Old May 25, 2011 | 11:33 PM
781m113's Avatar
2003 CLK 55 AMG
ic.. thanks for the reply.. you got any pics of your setup? id like to see what 20mm looks like..
Old May 26, 2011 | 09:42 AM
FatTony001's Avatar
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
Don't forget the spacers have to adjust with the wheels offset !
if your comparing with stock wheels then your fine...
just a head up before you buy some spacers
Old May 26, 2011 | 04:43 PM
MTLdude's Avatar
2005 CLK 55 AMG
I took one with my BB what's your email. Feel free to post it.
Old May 27, 2011 | 04:51 PM
781m113's Avatar
2003 CLK 55 AMG
thanks for the pic man. it actually helped me out a lot cuz i took a duplicate shot of my car and compared..
so im going with h & r lowering springs, 10mm front and 20mm rear spacers.. will post pics of the setup once its complete
Old Sep 8, 2011 | 10:43 AM
Ducatinicolo's Avatar
CLK 500 Brabus
Can I see some pics with your guys setup? I am looking to get a set of spacers for the rear and deciding on what size to go with my brabus wheels and eibach pro kit springs. Please post some! please!
Old Sep 10, 2011 | 05:51 PM
GiZzO's Avatar
CLK55 / E350 Coupe
Heres some before and after pics of 20mm H&R bolt version spacer + camber adjustment.
Lookin a little floaty cause its fresh off the jack.
Old Sep 10, 2011 | 11:42 PM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
I was running 10mm spacers in the front and rear on ET35 wheels but changed the rears out to 5mm as there was some fender rub after lowering the car. ET30 in the rear and ET25 in the front works great and gives it a nice flushed look on my 209.
Old Sep 12, 2011 | 12:36 PM
CLK 500 Brabus
Thanks for putting the pics up! Looks great. Do you have any idea what the biggest spacer you can get for the rears.. 30mm or 40mm? without affecting anything beyond camber/tire wear?
When you go that wide in the rear do you need to put a 5 or 10 on the front to compensate for the rears being so wide?
Nic
Old Sep 13, 2011 | 12:28 PM
781m113's Avatar
2003 CLK 55 AMG
****s hot
Old Sep 13, 2011 | 12:30 PM
781m113's Avatar
2003 CLK 55 AMG
cool. thx for the info.. ur ride looks sick. what kinda springs you put on
