CLK 55 amg rotors size
Rating: Thread Rating: 3 votes, 5.00 average.
Old May 20, 2017 | 12:22 PM
cm60k's Avatar
Yes, Clk500 should fit directly to your Clk270..
-;ZAYED;-
Old May 21, 2017 | 05:31 AM
vegeftw's Avatar
CLK 270
-;ZAYED;-
Even with the big 345mm rotors? I saw that Mercedes sell maximum 330 rotors for 2.7 even with sport packet. Mine doesn`t have that sport packet
Thanks for the prompt answer :-)
Old May 21, 2017 | 06:08 AM
cm60k's Avatar
Sure bro.,
even Clk500 345mm Rotors with calipers will fit to your hub directly,,
do you have 16" or 17" Rims..?
-;ZAYED;-
Old May 21, 2017 | 06:39 AM
vegeftw's Avatar
CLK 270
Sure bro.,
-;ZAYED;-
18". I checked the ET and they fit also. My only concern it was about fitting plug and play or need any adapter.
Thanks Zayed, very helpful as far as in Europe are not that many big engines so not not many make this kind of things
Old May 21, 2017 | 07:02 AM
cm60k's Avatar
Don't worry bro.,
Clk500 brakes should fit perfectly,
also, you can go with an OEM (345mm) plan or drilled Rotors as well..
-;ZAYED;-
Old May 22, 2017 | 03:09 AM
vegeftw's Avatar
CLK 270
Good news then. If anyone has a pair of calipers for sale, I`m ready to buy them if the price is right.
Zayed, many thanks again.
Old May 22, 2017 | 03:46 AM
  #32
cm60k's Avatar
Old May 22, 2017 | 11:01 AM
  #33
vegeftw's Avatar
CLK 270
I found someone who is selling r171 SLK350 calipers and just checked and they work with 345mm rotors. They look similar with the ones for CLK500. Are they the same, can I use them on my CLK27?
Old May 22, 2017 | 11:56 AM
  #34
cm60k's Avatar
R171 Slk350 uses (330mm) Fronts, and (290mm) Rears..!
-;ZAYED;-
Old May 22, 2017 | 12:11 PM
  #35
vegeftw's Avatar
CLK 270
-;ZAYED;-
Damn, you spoiled my happiness. I was checked on some website with Mercedes parts and they are selling rotors for R171 345mm. Maybe is some kind of mistake then. Thanks
Old May 22, 2017 | 01:11 PM
  #36
cm60k's Avatar
Yeah bro.,
Slk55 is the only R171 that came with 4-pot calipers (345mm) in "Feb/04 to Nov/04",,
then MB replace it with 2-piece 6-pot calipers (340mm)..
-;ZAYED;-
Old May 27, 2017 | 06:42 PM
  #37
vegeftw's Avatar
CLK 270
I found this R171 350 BREMBO 20791501 20791502. And it seems they fit C 55 AMG , C32 AMG , w209 clk500 also. They have 4 pots as you can see in attachment.
I also found the same serials on AMG calipers too
Are you saying that is it`s useless to buy them?
Attached Thumbnails CLK 55 amg rotors size-1.jpg   CLK 55 amg rotors size-2.jpg   CLK 55 amg rotors size-4.jpg   CLK 55 amg rotors size-5.jpg   CLK 55 amg rotors size-6.jpg
Old May 27, 2017 | 08:17 PM
  #38
vegeftw's Avatar
CLK 270
4 pot brembos 20704603 & 20704604, those are from a W171 SLK350, W203 C230 Kompressor..
Old May 27, 2017 | 09:35 PM
  #39
cm60k's Avatar
If you want to go with (330mm) Rotors, these "W203 C230K or R171 Slk350" calipers you found are the correct choice,,
but if you want to put (345mm) Rotors, you will have to get "W203 C32/C55" or early models of "W209 Clk500-Clk55/R171 Slk55"..!
-;ZAYED;-
Old May 29, 2017 | 06:49 PM
  #40
vegeftw's Avatar
CLK 270
Hi there Zayed.
Bought already calipers from a w209 500.
The interesting questions for now is if the calipers with fit W220 rotors 360mm. Found a pair for a good price.
Old May 30, 2017 | 12:00 PM
  #41
cm60k's Avatar
W220 Rotors won't fit for sure, they uses very high Rotor Hat, which is (76mm),
while you have to go with (46mm) Rotor Hat height,,
you can put non-drilled Rotors from "Clk500/550" or drilled Rotors from "C32/C55 or Clk55 or Slk55"..
-;ZAYED;-
Old Feb 19, 2019 | 11:21 AM
  #42
JimAMG's Avatar
2002 CLK 55 AMG
Are 2002 CLK 55 AMG front and rear OEM rotors supposed to have AMG imprinted on them?
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
