Oil Consumption
Old Apr 10, 2012 | 06:21 PM
armyfazer's Avatar
2004 CLK55 AMG
Oil Consumption
I have an 04 CLK55 with a thirst for oil. It has about 64k miles. I've owned the car for about 7k miles. Several times already, I have had to add a quart of Mobil 1. I don't see any obvious leaks. Are these engines known to be thirsty? Is there something specific that I can look at/for? Any help is appreciated.
Old Apr 10, 2012 | 07:29 PM
KENNY94945's Avatar
I believe they thirst for oil.
"7000 miles...several times...add a quart"
One quart every 3500 miles would not be bad.
Would could always do a leakdown and compression test to investiage valves and ring wear.
Old Apr 10, 2012 | 10:29 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Have a really good look at the rocker covers for leaks as they are easy to miss. Also check all the crankcase breathers aren't blocked (3 hoses, 2 smaller ones can block). Always check the dipstick instead of relying on the warning, the warning can come on too early if there is some sludge in the pan. 1-2 Quarts per 7000mi isn't anything I would worry about.
Old Apr 11, 2012 | 09:41 AM
armyfazer's Avatar
2004 CLK55 AMG
Thanks for the input. I will take another look around the engine. And if nothing is amiss, I guess that it is something to live with.
Old Apr 11, 2012 | 04:25 PM
achoren's Avatar
2002 CLK 430
I have not had that experience with my CLK (has 60k miles), though my last mechanic who worked on both my MB and VW said it's a chronic flaw/design feature (depending on how you see it) that German vehicles go through a bit of oil and need topping off somewhat regularly. Not necessarily a sign of something wrong/needs to be fixed, just a common trait.
