Carbon driveshaft
Old Apr 1, 2013 | 11:51 PM
2PRECISE's Avatar
clk55 amg
driveshaft has to come out completely and a measurement is needed from trans flange to diff flange.
Old Apr 2, 2013 | 02:52 AM
cm60k's Avatar
Originally Posted by 503C43 ////AMG
What measurements are needed and what is the cost for the drive shaft?
Jason,
Preferred if you can find a "C43/CLK430" drive shaft from junk yard,
and send it to the company to take an accurate measurement.....
ZAYED,,
Old Apr 3, 2013 | 12:53 AM
2PRECISE's Avatar
clk55 amg
you cannot measure the driveshaft, the center telescopes and you cannnot get an accurate measurement, has to be flange to flange with DS removed.
Old Apr 3, 2013 | 02:43 AM
cm60k's Avatar
Ah,, sorry, i didn't know about that,,
Thankss for clear it.....
ZAYED,,
Old Apr 5, 2013 | 09:10 PM
Thericker's Avatar
V12-Biturbo
Went to their website but no way to click or draw up info on CF shaft you bought
Originally Posted by 2PRECISE
Finally, another first........ Carbonfibre drivesahft for W208!!!! Still in the testing phase, but will be available for purchase shortly... stay tuned!!!
The info I previously got was from another Co in CA. Could you PM me pricing & where to measure exactly for my R230 SL? Thnx
EDIT: Just emailed them, if they can make 1 for my SL, it'll be ordered asap..
Old May 6, 2013 | 05:47 PM
ctravis595's Avatar
2002 CL500 to CL55 conversion
i have some questions about the transmission output flange that you guys are talking about -
im installing a used transmission, but the used transmission came with the 4 bolt output flange, from what i've read in this thread it's not as simple as unbolting the 4 bolt flange to add the 3 bolt flange?
if you could simply swap out the flange maybe it would be a lot easier for people to make this upgrade if they have the 3 piece flange
Old Dec 20, 2013 | 11:30 PM
  #32
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
I know this is an old thread but I was curious if anyone found out if there is a carbon fiber drive shaft for the SL600/65?
Old Dec 31, 2013 | 07:18 PM
  #33
EVOII_Racer's Avatar
Mercedes Evo II
Since you brought the thread back...
Which company makes these carbon driveshaft?
Old Jan 1, 2014 | 12:18 PM
  #34
2PRECISE's Avatar
clk55 amg
driveshaft shop.... FYI carbon driveshaft's do not just bolt in, you have to remove the center support completely even the mount from the body. The shaft because its carbon needs to be larger in OD and is very close in a couple spots.
Old Nov 18, 2017 | 11:02 AM
  #35
Raul Camacho's Avatar
Clk 430
driveshafts are available for sale. FYI the carbon shaft requires you to remove the center support for the stock driveshaft.
interested, can you send link
Old Dec 17, 2021 | 04:42 PM
  #36
quik55's Avatar
2000 ML55 AMG 2001 CLK55 AMG coupe 2002 CLK55 AMG Cabriolet 2025 BMW M2 6MT
Anyone have a driveshaft for sale? W208 AMG?
