OEM or AM HID's & cant get dyno mode to work
Old Apr 20, 2013 | 11:56 AM
Darren_0203's Avatar
03 CLK55 AMG, 02 C240
Need a new hid headlight, should I stick with OEM or are any of the aftermarket ones just as good? Also I searched dyno mode for hours and can't get anything I found to work. My srs restraint light comes up when I start the car, will that prevent it from going in dm? The dealer is taking care of it for free but haven't had the time to get it there.
Posted from Mbworld.org App for Android
Old Apr 20, 2013 | 03:02 PM
mercamerica's Avatar
'06 CLK55 AMG Cabriolet
I'm pretty sure there isn't dyno mode for the the 2003 model year
Old Apr 20, 2013 | 05:30 PM
Well that would definitely be bad news for me, any way to turn off the traction control off? Anything on HID bulb info?
Old Apr 20, 2013 | 07:48 PM
ChiCho55AMG's Avatar
W209 CLK55 AMG Kompressor, ATV BRP 800 CAN-AM
DYNO MODE for your W209 2003 :
1- Put the key in the ignition position 1
2- Within 3 second after the ignition is turned on to position 1, push the "reset bottom 3 times then A display Voltages manual should appear on your cluster.
3- Use the arrow up/down on your steering wheel to change the screen until you see "Dynomometer testing" manual
4- Use the "-/+" on your steering wheel to turn the ESP ON/OFF for Dynomometer testing.
Old Apr 20, 2013 | 07:51 PM
Pretty sure u can use my above post to test the dyno mode on your car because all has the same method
Old Apr 20, 2013 | 08:09 PM
I've tried that a couple times, even on different screens. Maybe it's the SRS restraint notification that wont let it go into dyno mode, it would make sense as Mercedes probably wouldn't want the owner dynoing the car if there are any malfunctions. IDK, but i'm getting that taken care of soon.
Old Apr 20, 2013 | 09:10 PM
I stand corrected
maybe this thread helps
https://mbworld.org/forums/clk55-amg...track-day.html
as far as the headlights go, I have limited knowledge but I would say that if you have the OEM headlights, than I would just replace it with another OEM
