Resolve costly inner edge tire wear
Old Jun 18, 2013 | 10:02 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
The very latest K-MAC patented design front Camber, Caster and Rear Camber
Toe Kits are now available to suit virtually every model Mercedes 1968 to 2013.
Majority of today vehicles, because
of cost cutting and speed of the assemble
lines only have Toe adjustments.
K-MAC Engineering
Toll Free 24/7# 1888 414 0762
sales@k-mac.com
www.k-mac.com
K-MAC Engineering - YouTube
Unlike the O.E front “one setting” offset bolts all K-MAC kits provide precise adjustment
(accurately under load, direct on alignment turntable) and more than twice the adjustment range.
This increased range and precise adjustment capability means at last ongoing issues of steering pull to one side, straight line high speed directional control, excess inner edge tire wear or being able to reduce lap times by increasing front negative Camber on race days can now all be resolved.
Fitting of these front and rear kits requires no special tools and allows future ongoing adjustments when altering height, fitting wide profile tires or simply to re-adjust for curb knock damage.
The adjustable front caster bushes also reduce dive, lift under brake and acceleration, along with improved steering response and traction under braking. They feature a unique K-MAC 2 axis/all positional bush design. This allows suspension arms to travel through their required arcs without binding. Also having twice the load bearing area of OEM rubber bushings that use air voids which can cause vibration, wheel hop with loss of traction under braking and subsequent premature bush failure.
An added bonus with the K-MAC adjuster kits is an entire bush upgrade as these 4 bushings for the front and the 4 for the rear are the vehicles main high wearing suspension bushings.
Example of K-MAC bushing strength/quality is the near identical bushings being used in the current Australian and New Zealand V8 race category where the G8 versus Ford. This all out competition racing – main straight top speed, then hitting race curbs, slamming down after becoming airborne! After 18 months of evaluation race scrutineers ruled the evidence had shown that for the safety aspect and reliability no other front end Camber and Caster adjuster kits other than K-MAC would be allowed to be used. The opposing Ford drivers were also instructed likewise.
Re Mercedes rear K-MAC Camber kits (also virtually every model 1968 to 2013) these new patented design kits get traction/power to the ground and are also precisely adjustable (up to 1.75 degrees positive or negative) capable of returning alignment settings to OEM specs in most instances. Whether through altering vehicle height, wide profile tires or curb knock damage.
All are supplied with bush extraction tools allowing these rear kits to be installed on vehicle.
Another special feature is that these Camber adjusters also include additional Toe adjustment (doubling the existing OEM adjustment range) correctly accommodating therefore for the new rear Camber facility.
Genuine K-MAC since 1964. First with front and rear Camber, Caster kits to suit Mercedes and world's largest range
Audi to Volvo
