FS: H&R front coilover springs $200
Old Aug 11, 2013 | 12:41 PM
greekspec2's Avatar
2005 C55
for you KW owners I have a set of H&R front coilover springs that where powder coated KW yellow asking $200 shipped
springs are 40mm shorter 245mm than KW's 285mm which allows you to have the front perch higher on the strut and have a lower drop without having to use spacers on stock or most wheel setups
Old Aug 12, 2013 | 02:03 AM
13lovecar14's Avatar
e300
this wheel look great, so it is.
Old Sep 5, 2013 | 09:36 AM
greekspec2's Avatar
2005 C55
offers
Old Oct 23, 2013 | 02:59 PM
greekspec2's Avatar
2005 C55
here are the full H&R front spring specs...
free length 145mm
full block height 84mm
loaded height 135mm
avail spring travel 61mm
spring rates....
working rate 286lbs
fully blocked 373lbs
static load 212lbs
