No Crank Pulley for 06 W209 CLK55 AMGs??
Old Sep 21, 2013 | 09:52 AM
FFXF1's Avatar
2003 Chevy Tahoe
Just visited the local tuner's shop to start the process of cat/res delete with ECU/TCU tune.
Was told nobody currently makes an upgraded crank pulley/belt set for the 06 CLK55, and none to be had.
Does anyone know of a set that may be available, or suitable alternative??
FFXF1
Old Sep 23, 2013 | 01:30 PM
az55amg's Avatar
03' CLK 55
I bought the German Power Tuining (theyhave a new name) a few months ago, for a lightened crank pulley, great product, just havent found a set per say... Google GPT
Old Sep 23, 2013 | 01:57 PM
HCUBED's Avatar
W209 2003 CLK55 Coupe
http://germanpowertuning.com/
Old Sep 23, 2013 | 10:44 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
With time and patients you could fab one on a Bridgeport or Lathe. A foundry or millwright might fab one to spec as well.
I bet someone out there fabs custom pulleys.
Gator
Old Sep 24, 2013 | 01:29 PM
ML63 AMG's Avatar
CL63 AMG
There are some available on ebay too I believe. Last I checked they were only $315. Search for AMG pulley.
Old Sep 24, 2013 | 04:31 PM
FFXF1's Avatar
2003 Chevy Tahoe
Perfect! Thanks guys, Greg
Old Sep 26, 2013 | 08:14 AM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Upgraded HB for M-113 N/A
there is a Fluidampr HB for our Motors , It is not widely known & Not listed anywhere. I personly have them on my owns cars . CLK 55 AMG & 03 ML 500. The motor's are smoother & Quieter. It is a little heavier than the OE , The motor revs better and I saw a 4 rwhp increase. You will also need a new ARP bolt .
I've installed 6 of these and had no issues.
Cheers _PTEngineering
Attached Thumbnails No Crank Pulley for 06 W209 CLK55 AMGs??-dsc00923-copy-2-.jpg   No Crank Pulley for 06 W209 CLK55 AMGs??-6-small-.jpg
Old Sep 26, 2013 | 11:36 AM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
part #'s and costs?
they are not listed in either mfgs catalogs
how complicated/long is the r/r?
Old Sep 26, 2013 | 11:59 AM
cm60k's Avatar
Did anyone tried this Crank Pulley:
http://www.ebay.com/itm/Mercedes-Benz-Power-Pulley-W209-CLK55-AMG-CLK350-CLK550-W208-CLK55-CLK430-/231002167204?pt=Motors_Car_Truck_Parts_Accessories&hash=item35c8cd57a4&vxp=mtr
ZAYED,,
Old Sep 26, 2013 | 05:32 PM
PTE's Avatar
PTE
Fluidampr
I'm very aware that it is not listed, They made a limited production run and sold only to a select group of dealers. I am not a vender on this forum so I'm not permitted to sell as a vendor or have the special privileges bestrode to a paying vendor , to do business on this forum. . But anybody whom has dealt with me , will tell you I'm a Jam up person , and in good standing within the MB world community. Cheers _PTEngineering
Old Sep 26, 2013 | 05:50 PM
cm60k's Avatar
Hey Patrick,
We all know you are always a helpFUL friend, i learned & will learn a many things from your great posts....,,
by the way; do you have any idea about the Pulley, which i listed from E-bay above.....??
ZAYED,,
Old Sep 26, 2013 | 09:36 PM
blackbenzz's Avatar
haters crazy
I can vouch for Pat. Great guy and knows what he's doing!
Old Sep 27, 2013 | 11:44 AM
GatorMB's Avatar
The CNC has the light, You should be able to find a local machine shop with one of these. The CNC require custom programming but its the way to go these days. They can laser scan your OEM and shrink or en-large. (wife's wish)? LOL
Pop was a tool and die maker for aircraft parts, when the going got tough on these early CNC milling machines they had him. The Bridgeport is far outdated but with attachments and fabbed dies, aircraft was mass produced.
Gator
Old Oct 1, 2013 | 07:36 AM
ricky87's Avatar
I don't see anything out of place. Motor mounts look good and there is no vibration at any other rpm. Steering wheel is rock solid at all speeds.
Old Oct 26, 2013 | 04:49 AM
Pauljay's Avatar
'00 Mercedes 430/55 clk cabriolet
A quick question for PTE!
You mentioned that Fluiddampr pulley allowed the car to rev better, I take it you mean faster?
How is that if the pulley is heavier than OEM?
I'm asking because I want to get a lightend pulley for faster engine revs!
Old Oct 29, 2013 | 07:27 PM
PTE's Avatar
PTE
The 4 Horse power increase showed from 2400 to 4800 rpm. That generally makes the 1000 ft times lower. Plus in my ML which has hard durometer rubber engine mounts , you can feel the smoother motor
Old Nov 5, 2013 | 12:52 PM
GatorMB's Avatar
When you guys change the weight of the Crankshaft reciprocating mass there will be an out of balance factor.
Dynamic engine balancing is accomplished @ Harmonic balancer/dampener and weights on the flywheel/flexplate. Custom engines are normally balanced by weight with measurements of each piston and rod Assy. further balancing is accomplished by crank shaft counter weight and final dampener/flexplate tuning.
we normally swap pulley's to accommodate supercharger final drive ratio. The final dynamic engine balance is not effected much with this mod.
To obtain different torque characteristics we adjust the final reciprocating weight @ the flywheel normally on circle track stick cars.
The Carbon Fiber drive shaft is the newest tech I have read about to address this concern.
All the Best, Gator
Old Nov 5, 2013 | 09:58 PM
2PRECISE's Avatar
clk55 amg
I will be making an ATI balancer to fit soon.. It will use a corvette or supra outer ring and make the inner hub to spec.
