Transmission cooler help
I decided to repost here since you could be more used to do this kind of mods than the guys with the "normal" CLK!
Some thoughts would be apreciated.
https://mbworld.org/forums/clk-class...oler-help.html
I have heard the argument where the transmission "warms up slower" but I think it's BS. The purpose of the radiator pass through is for cooling not warming. Regardless, you can do it either way. I doubt you will notice a difference.
Why are you trying to upgrade the stock cooler? Are you putting down more power than stock?
I'm affraid that the extra cooler could not be enough, since in other stock cars they use both the extra and the internal one!
About the thermostat, does it close the circuit 100% to the cooler or is allways open?
PS: CLK320 CDI - stock 224hp and 515Nm
