E63 Trans mount for w208 55?
Old Jan 9, 2014 | 01:02 AM
OGCLK320's Avatar
2004 E55 AMG, 2008 G55 AMG
I just ordered the E63 trans mount for my 01 55 I was told by a friend of mine that is a mercedes mechanic that they are interchangeable. Has anyone else done this on their 55? I heard something about E55 motor mounts being superior as well. Looking to order soon, thanks for any help.
Old Jan 9, 2014 | 01:33 AM
cm60k's Avatar
I think E63 uses 3 bolt holes with #: "212 240 10 18", while CLK55 uses 4 bolt holes with #: "212 240 04 18", isn't...??
Name:  e63 mounts.jpg
Size:  4.1 KB vs Name:  CLK55 mounts.jpg
ZAYED,,
Old Jan 9, 2014 | 01:47 AM
cm60k's Avatar
If you need to replace your Engine mounts soon, prefer to go with W211 E55K mounts #: "220 240 27 17",,
i used them in my C55, and happy with them.....
ZAYED,,
Old Jan 9, 2014 | 05:30 AM
KJI3jflarryfe93's Avatar
ZAYED,,
hi Zayed
does w211 E55K motor mounts fit w202 chassie?
do you know if they are solid rubber not oily filled?
do you know if those round metal plates are included in the box or needed to be changed along with the new mounts?
Old Jan 9, 2014 | 05:48 AM
cm60k's Avatar
Hey Dennis,
Sure they fit perfectly with W202, i have them already,
unfortunately i didn't inspect them if rubber or oily,,
those white plates are rubber, i think they're for heat protection, and sure they comes with a mounts as kit.....
ZAYED,,
Old Jan 9, 2014 | 10:37 AM
OGCLK320's Avatar
Attachment 275894 vs Attachment 275895
ZAYED,,
That middle bolt on the 55 mount cant do much right? It just holds that little plate in place.. As long as the other 3 line up well I should be fine. I heard these mounts will last twice as long as the original 208 55 mount.
Old Jan 9, 2014 | 10:38 AM
OGCLK320's Avatar
Hey Dennis,
Attachment 275897
Attachment 275898
ZAYED,,
Are your E55k mounts made by corteco? Thats all i seem to be able to find right now..
Old Jan 9, 2014 | 11:15 AM
cm60k's Avatar
Yes, 2 bolts may enough,
also im not sure about the line between top bolt & down bolts, if it a same shape or not....??
i didn't compared between them, i think they're the same....!!
ZAYED,,
Old Jan 9, 2014 | 11:16 AM
cm60k's Avatar
Not sure, didn't check that, usually MB deals with "Corteco/Boge/Lemforder".....
ZAYED,,
Old Jan 9, 2014 | 03:46 PM
Hey Dennis,
Attachment 275897
Attachment 275898
ZAYED,,
thanks bro
partsnumber is it the same for both left and right side motor mounts?
A 220 240 27 17 (L + R)
Old Jan 9, 2014 | 04:14 PM
cm60k's Avatar
Sure bro., L/R are the same, you can go with "220 240 27 17",
also there is a new #, which is "211 240 19 17"......
ZAYED,,
Old Jan 10, 2014 | 03:26 AM
ZAYED,,
as long as these newer motor mounts are better and stiffer than w202 and w210 M-mounts I would instead use 55K parts as an upgrade.
