wider spray washer nozzles - W209
Old Jan 12, 2014 | 10:28 AM
Eville's Avatar
2005 CLK 320 Cabriolet
Does anyone know if it is possible to upgrade the windshield washer nozzles to have a wide spray? Mine each shoot one solid stream of fluid, one midway up on the left, and one 3/4 of the way up on the right. I would like them to spray either a cone midway each or a flat spray midway. Any options?
Old Jan 14, 2014 | 09:35 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I thought you meant nitrous nozzles Sorry, dont know about wiper spray.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
