Quaife issue
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
I had a similar issue on 3 E55's I fitted Quaifes to. I ended up using thick rubber o-rings, lots of grease and a heavy rubber mallet. Once they're in you'll need 2 pry bars to get the shaft out but I figure if the o-ring ever failed it wont do anywhere near the damage a metal clip would do.
The car I did that fix to first has been going 5 yrs without popping a drive shaft.
the clip is a wire in the shape of a "C" ... so u put ur fingers in the opening of the "C" and open it to the shape of a "U" but not that much. u keep bending it till and installing axle until it clicks in.
