Might buy a 2005 CLK55, need your opinions and info
Old May 20, 2014 | 02:47 PM
ROLLNNN's Avatar
2005 CLK320 Vert & 2005 CLK55 AMG
Hey everyone,
I've been reading this section for a few days now and have found some very useful information. It was just very spread out and hard to find it again. Hopefully you can help me out. I'm considering purchasing a 2005 clk55 with 105xxx miles. I had a MB mechanic look at it and he said everything looked good except, the rear main seal is leaking, I would need to change the valve cover gaskets and engine belt.
I see that these are normal or regular occurrences. Are there any other problems, big or small that i should be concerned about? If i purchase this I'm going to have these things taken care of right away. Can you recommend any other immediate preventative maintenance?
Thank you!
Old May 22, 2014 | 03:58 AM
jkiddd33's Avatar
2005 E55 AMG
I have an 05 clk55. Standard maintenance. Nothing to be concerned about if youve had it inspected.
How are the brakes? Those are costly so it be nice if they were done recently. Besides those, valve covers, plugs, tranny service is about all you need at that mileage.
Old May 23, 2014 | 02:52 PM
ROLLNNN's Avatar
OK great, thanks. The brakes had fairly new rotors but the pads need to be replaced.
hmm, ok. decisions decisions...
Old May 23, 2014 | 03:08 PM
ambit's Avatar
09 CLK550
My OEM front pads were $110/side
Other common issues:
https://mbworld.org/forums/clk55-amg...-problems.html
I seem to go through keyless-go door handles
Old May 23, 2014 | 04:55 PM
ROLLNNN's Avatar
Thanks Ambit. I normally use ceramic pads. OEM dust too much for me.
It doesn't seem like these cars have too many problems if they're serviced correctly...
Old May 24, 2014 | 11:53 AM
City Rat's Avatar
Veteran: Army
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
Great having an independent give it the once over but I suggest that before you are ready to really pull the trigger you take it to an MBZ dealer not associated witht the sale and have them do a PPI, pre-purchase inspection. Just about the same inspection that they do before putting a car in their CPO program. The thing that the dealer can do as part of the inspection is give you a maintenance checklist for that car based on the inspection. Further they can pull the cars MBZ service records and see what has been done to the car as well as the car history with MBZ so past owners and locations. I use the PPI as my last cross check to verify car fax or any oral history that the seller has told me, e.g. "I'm the only owner", "It was always serviced at X dealer", "Everything works" "allservice is up to date", etc. On the last two transactions, PPI's have saved me literally nearly $14k on avoiding cars that looked, sounded and drove great. Good luck.
Old May 24, 2014 | 01:57 PM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
Hi Roland! If you plan on getting into a W209, 05 CLK55 is one of the best examples. +1 on what everyone else says, but I would add:
  • Find out if/when the voltage regulator was replaced. this is a consumable item (at 60K miles)
  • Find out the last time the Camshaft and Crankshaft position sensors were replaced. The car will leave you stranded if they go out.
  • AC Stepper Motor
  • Rear Seal
  • Valve Gaskets
  • Transmission Plug (harness going into the tranny leaks oil)
  • Seat Warmer
  • 3rd Brake light
  • Engine Motor Mounts
  • Tranny Mounts
  • Seat belt Mechanism (that pulls the seatbelt back in)
  • That damn "SOS Malfunction" indicator
  • Various Suspension bushings
  • Headlight Xenon ballast
  • Windshield wiper adjustment
  • Sunroof adjustment
As far as mods, take a look at what I have done and 99% of what I did can be done on the CLK55. Betrezra is the top dog around here as far as w209 CLK55s so take a look at his threads as well.
Good Luck, let me know if you have any other questions about this.
Old May 24, 2014 | 02:20 PM
City Rat's Avatar
Veteran: Army
  • AC Stepper Motor
  • Rear Seal
  • Valve Gaskets
  • Seat Warmer
  • 3rd Brake light
  • Tranny Mounts
A lot of the items on this list are the kind of things that the PPI would catch. In my instance I got a list like this of items encountered then I had them schedule out what was urgent, needed in the next three months, next six and nine months, etc. That really helped prioritize and flesh out my PM schedule for the car.
Old May 25, 2014 | 01:26 AM
DiceCedes's Avatar
21 AMG GT Stealth Edition
Rollnnn-
I can chime in on my experience with the 05 CLK55. I too had an 05 C230. But the day I purchased it new, what I really wanted was that CLK55 on the lot. It was over twice the price so there was no way I was going to get it. So, a few years ago, the cars were no longer $35K apart and decided to sell the C230 and pick up a CLK55. The C was off warranty so I figured that if I was paying the maintenance it may as well be on the CLK.
I found an 05 with what I considered a lot of miles but a great service history. It was serviced by the same dealership where I have my cars serviced. I had a PPI done and it showed that the rear main seal needed to be done also. I did it as soon as I purchased it.
In the years that I have owned it, I had to replace valve gaskets both sides, transmission conductor plate, transmission o-ring, secondary air pump, fuel system purge valve and a window regulator.
I still enjoy the car so I hope this helps you make your decision. Feel free to PM me with any additional information you need.
Old Jun 3, 2014 | 06:27 PM
Nachtsturm's Avatar
2015.5 Volvo V60 Polestar
Do it. If its a coupe you will be only one of the 247 05 Coupes.
I have had over 50 cars. My 05 CLK55 is the longest I have ever kept a car by a large margin. Definitely my favorite I have owned.
I only have 35,000 miles on mine and is stored during winters, but it has been very reliable.
I have been toying with the idea on replacing it with either a Twin Turbo E550 coupe or C63 coupe. Though the GLA45 and Macan also have my interest. We will see.
I definitely say go for it.
Old Jun 3, 2014 | 06:37 PM
ROLLNNN's Avatar
awesome, thanks for the info everyone!
