C class 18" split spoke fitment on CLK55/63
Old Mar 29, 2015 | 06:00 PM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
Anyone know if the C class 18" split spoke (ET 30f/34r) off the 05/06 C55 will clear 05/06 CLK55/63 6 pot front?
I think the 05/06 CLK 18" split spoke is 37f/30r so the C class wheels will sit out more on the front but sit in more on the rear.
Anyone have better info?
Old Mar 29, 2015 | 08:36 PM
///AchMeinGott's Avatar
none... for now
I know guys have fit the 6/4 piston brakes(on stock rotors) on C55's. With the nearly identical front clip, they should fit 05/06 CLK's. Probably 03/04 as wella
Old Mar 31, 2015 | 04:30 AM
cm60k's Avatar
Front stock Rotors will fit, but rears doesn't, cause stock rears (2) pistons uses 300mm, while CLK55/SLK55 (4) pistons uses 330mm..!!
ZAYED,,
Old Apr 1, 2015 | 11:20 PM
lowpost's Avatar
My question must have been confusing 'casue I was taking about rims. I think I figured it out though. C55 wheels will fit, but the rears offsets aren't aggressive enough. I'm better off buying new CLK55/63 wheels.
Old Apr 1, 2015 | 11:49 PM
greekspec2's Avatar
2005 C55
do you have 6pot/4pot brakes on your ride now?
i'm local and can let you test fit
