A/C Recharge question
Old May 12, 2016 | 10:03 AM
Marcello's Avatar
2002 CLK55 AMG Cabriolet
My mechanic says "don't do it"! Dealer service department says "never do it"! I've got to believe that todays products work great. So here is the question: Can I purchase R134a refrigerant that meets the specs for my 2002 CLK55 AMG without destroying the A/C system. Thanks!
Old May 12, 2016 | 11:01 AM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
Yes,
R-134 refrigerants are all about the same with the exception of oil and dye additives.
Our cars use pag 46 oil and dyes are a waste unless you have a UV light for leak checks. Do not add oil unless a major component was replaced or a massive leak was repaired.
I was advised to avoid buying freon made in china but for short terms and leak testing it might subside. I was told it cools fine but might contain corrosive or incompatible additives.
I picked up a case at wal-mart made in india for some repairs on the fords I have.
Cheers, Gator
Old May 12, 2016 | 06:41 PM
cindyclk's Avatar
check my reply in the 208 section.
