Vanity mirror help
Old Jul 20, 2016 | 10:23 PM
sksvlad's Avatar
2004 Mercedes CLK55 AMG
Vanity mirror help
Weird but either my family or my mechanic cracked my driver side vanity mirror, how much of a headache is it to replace it?
Old Jul 21, 2016 | 02:27 AM
Khan 55's Avatar
2004 CLK55 AMG W209
Easiest solution is to find a new visor complete from a junk yard if possible. Opening that up might not be difficult but closing it may require some upholster skills or sewing techniques. But I think they made from some like plastic foam or something so as mentioned above, rather get another one.
Old Jul 25, 2016 | 07:12 AM
Kamisama's Avatar
E500; ML63; X5M; LR3
Vanity mirror in 2004 CLK55 should come out with the plastic mirror enclosure if it's like the E-class (looks same to me). There are four retention points and if you pull in the right area the mirror enclosure is easy to remove. The mirror is held in place with simple plastic retainer clips that are part of the enclosure. You should be able to change without any problem. Pictures appear the same. No upholstery skills needed.
