Maximum tire width on W208 CLK?
Old Nov 25, 2016 | 09:43 PM
ReddZedd's Avatar
1999 CLK 320 Convertible
I was wondering the maximum width tire I could fit my W208 CLK with (staggered), without any rubbing in the fenders.
Old Nov 27, 2016 | 11:44 AM
KJI3jflarryfe93's Avatar
i'm using 255 continentals in the rear on my c43 without issues.
your clk is a w202.
some tires will rub others won't.
don't go to wide as you don't know if it will rub or not?
Old Nov 28, 2016 | 07:25 PM
sick430's Avatar
CLK Cabrio
265 no problem
Old Dec 5, 2016 | 07:45 AM
Chappy's Avatar
AMG
265-35-18 easy (rears), depending on wheel offset and suspension setup. My ET25 rubbed slightly in rear but the Monoblock II did not.
I have used 235-40-18 in front and now use 225-40-18 Michelin Pilot SS.
Old Dec 31, 2016 | 11:50 PM
HPDECLK55's Avatar
Veteran: Navy
2009 SLK 55, 2010 ML350
235/265/19s on mine, lowered, with no problems at all.
Old Jan 1, 2017 | 01:18 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
I think Improviz had 275s on his
Old Apr 27, 2021 | 03:07 AM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
I know this is old but still thought it might come in handy for those that are still wondering.
Wheels are AMG Monoblock Type 2 in 18" (Standard on W210 E55 AMG)
My wheels were factory-fitted from MB.
I upgraded my tire sizes from
Front: 225/40 to 235/40
Rear: 255/35 to 265/35
Tire Brand: Hankook Ventus V12 Evo2
I also installed 12mm spacers from H&R at the rear only.
As a preventative maintenance issue, I also replaced the front lower control arms.
And installed camber bolts for wheel alignment purposes.
All good, no rubbing on the fronts at full lock. Rides great and firm.
