A few W209 questions
I haven't changed the oil (synthetic) in over 2 years but have not driven even 3K miles. Is this OK?
When I got inspection sticker the fellow said the brake fluid was fouled because of the color of the fluid when he looked at it. What color should it be? How often should there be brake fluid service?
Wife has dinged up the front lower bumper that houses the fog lamps. Easy to do if there is curb when parking. What's the most economical way to repair/replace this? Car looks great other than this.
Shock absorber for trunk partition is bad and I'd like to know my best bet for replacing this? Right now I'm having to jam a plastic stick against the partition to be able to put top down.
Any preventative maintenance I should do proactively to avoid future costly repairs?
Does entire brake system need flushing. Does brake fluid need to come from MB only?
If you can and it's not outrageously expensive, get the Benz fluid. If not, get a quality one anyway, like ATE and such.
