W208 2jz swap or m113k? Any advices?
1 Post
Mercedes SL55 AMG - BMW X6
Im buying a 1997 clk320 for a track buid, i have an sl55 amg few mods dyno 587 whp 628 wtq c
+ 100 shot of nitrous and didnt dyno it after nitrous, car its been wreck on the side n insurance wont pay me, now im buying a clk320 just for track, whats a better swap the m113k that I already have everything, or part it out and put a 2jz in it? Any suggestion or ideas
E55 AMG (SOLD), EvoSport CLK (SOLD), 2013 GsxR 750 (SOLD)
What mods did you have on your SL55 that bumped up the power that much both in HP and TQ?
Also... what type of dyno did you use?
To answer your question... I'd suggest a M113k swap. It's much easier than a 2JZ. You can fit Mercedes Parts easier than those of a JDM setup.
1 Post
72mm fixed sc pully, belt wrap kit, intake, deleted cats, 3 inch exhaust, tcu tune,lsd, heat exchanger, johnsonson pump, lsd, ngk colder plugs, eurochargrd tune, im forgetting some stuff probably dynojet dyno
I say, be the guinea pig for many of us and go the 2jzgte 3litre twin turbo straight six route. I will tell you now, don't bank on the 722.6 gearbox working with a 2jzgte even with a custom bell housing. You would have to run the manual 6 speed Toyota box and aftermarket ECU. I still don't know how will the car work as someone mentioned before, there is too many electrical computers such as the SAM modules that work together with ECU and TCU and then the cluster to allow for engine vitals and the brake system that is probably engaged by that. I have seen someone on the net fit a 13B motor to a BMW M6 so maybe it is possible. But to be safer and not regret it half way down this line, rather fit your SLS motor in there.
GatorMB (06-03-2017)
2002 CLK 55 AMG cabriolet Eurocharged
He is right, I just viewed one of these engines fresh from japan retrofitting into an earlier non turbo supra. The entire dash was out along with the front clip of the car while all the wiring was getting customized.
Happened to be there getting some tig work done.
1 Post
2jzgte,ecu,wiring,auto trans $2200 for $500 i can get a 6 speed 350z and get an adapter, or 1jz 5 speed trans $600 theres many options for the trans, the best would be the supra 6 speed getrag very hard to find, i found one 2jzgte+ecu+wiring harnesses+6 speed getrag trany for $9000.
I want to build a 900 whp car im looking at the longer run,
Here r some interesting facts ....
2jzgte 900whp set up (stock internals)e85 tune
$10,000
Precision singlTurbo GT42 Ball Bearin hp985
$3k
60mm wesgate $520
Arp headstuds $150
2JZ GTE TIG INTAKE W/90mm THROTTLE BODY w/ fuel rails $640
Top mount turbo manifold $440
Godzilla bov $340
DeatschWerks 1200cc Injectors $845
5 inch, Intercooler piping flanges $1200
Aeromotive Fuel Pressure Regulator $170
Hks 272 cams $564
2 walbro fuel pump 450lph $320
aem ems series 2 standalone $2000
SERIES 2 KEY FEATURES
Plugs directly into the factory harness. No rewiring necessary.
Uses all the factory sensors.
Includes start up calibrations.
System is fully enabled and unlocked - Never pay for upgrades!
Context sensitive help eases tuning process.
Maps can be password protected by the tuner to prevent unauthorized usage or sharing.
Runs on Windows-compatible software.
12 peak and hold injector drivers (Supra only).
8 direct-fire coil outputs.
16 general-purpose outputs.
8 definable switch inputs.
4 EGT inputs with fuel control.
1MB of internal data logging.
Electronic boost control.
Full idle control.
Programmable traction control.
Software definable knock control.
Two step launch control.
User configurable soft-cut rev limiters.
Wet or dry nitrous control.
Tune using new USB communication port or serial port.
Works with all AEM gauges.
Runs on Windows Based Software
Install in Minutes
16/32 Hybrid High-Speed Processor (more than you need)
Base Maps Included
Onboard Data Logging
Sequential Fuel Injection
Interactive Manual (user friendly in every way)
Boost, Knock and Nitrous Control Schemes
Operates with all factory sensors and wiring
Mk113 900 whp set up +$23,410.00
Mbh header $2885
Kleemann cams $2400
Wistec supercharged $7999
Bosch ev14 1200cc injectors $1081
Speed driven ecu standalone $7995
Fuel pump upgrade $350
90mm tb $700
Ect
I already have the mk113k i have an sl55 amg i got rear ended n its totaled, now i can part it out, engine trans supercharged, brakes, ect ect and get close to $8k parting it out.......
I been thinking alot and adding $, it would be a track car and i think the 2jz could be easier to tune find parts ect...... im still a mercedes fan, droping it in a clkw208, imagine a clk at a red lightðŸŽ, manual, huge turbo, 🚀2 step antilag sound 🎉ultimate sleeper..... 👨ðŸ½*🌾 what do you guys think
$10,000
$3k
60mm wesgate $520
Arp headstuds $150
Godzilla bov $340
Hks 272 cams $564
Full idle control.
Install in Minutes
Base Maps Included
Mbh header $2885
Kleemann cams $2400
90mm tb $700
Ect
1 Post
I know its missing a lot (ect) n i stop counting at 23k, list goes on n on n, the speed driven standalone its not really necessary, injectors n pump i already have it, i was planning on tuning my sl55 on e85 b4 i got hit
Clk 55
He retrofitted a k engine into a na chassis.
fitting a V8 k engine into a v6 chassis is a VIP 320 question.
VIP 320 is here you just have to pm or search his build threads. He's poineered many w208 attributes.
Cheers
Cheers
Yes I have done the swap. Actually I'm selling the engine and trans ready to drop in to w208 with slim electric fan and custom upper radiator fan, engine harness, and ecu to make it all work
how much track driving experience do you have? and if any in what type of car? your SL sounds like a drag car, thats why i ask.
i wont say too much on this topic until you can reply - but i track my 208 CLK55 a few times a year (3-5) and do a lot of autocross. there is a big weight distribution issue on the 208 chassis, way too much weight in the front and the easy weight savings on the car is mostly in the reat, only making matters worse - so whaever you do with the engine think about which setup will take the most weight out of the front of the car. also you cant run much wider than a 245 front tire on this car without modifying the front fenders.
if i were you i would get the wheels/tires/suspension/brakes/interior all sorted for track and do a few events in with the current engine and see what you think the chassis needs most. i love this car but if your talking about doing 500hp+ build then plan to spend a lot of time getting the things i mentioned above sorted. the thing i love about track driving over drag racing is that the driver and car setup are great equalizers. a good driver can make up for 200hp or 1000lb weight advantage versus an inexperienced or just plain poor driver in a power heavy car.
l look forward to hearing back from you on your plans. I would love to have more 208 chassis on the tracks to talk to and maybe compare lap times! as far as i know there is only 1 person other than me on this board that does track day/autocross regularly with these cars.
