W209 CLK55k BOOST gauge pod?
Old Jun 6, 2017 | 03:03 AM
Chris Huynh's Avatar
W211 E55 amd W209 CLK55-kleemann
I've been looking all over the net in search of a 52mm single, double or triple gauge that's made specifically for our car but couldn't find any? My CLK55 is boosted with kleemann kknpressor, in running 3 gauges, but currently only 2 are set up which is boost and fuel pressure gauge, the 3rd is going to be a wide band gauge. However, I couldn't find any pillar of dash mount gauge pod that's made to fit our car beside the universal one? You guys have any ideas where I can get it?
Attached Thumbnails W209 CLK55k BOOST gauge pod?-photo32.jpg   W209 CLK55k BOOST gauge pod?-photo840.jpg
Old Jun 9, 2017 | 07:05 PM
Hello, anybody??
Old Jun 19, 2017 | 06:00 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
I am installing mine tomorrow will give a photo shot.
Not proud but it is going to suit my needs. I used a carbon fiber grade el-cheapo and broke out the dremel. The carbon fiber has a checkered black/silver look that works with my color combo.
The gauges are mounted and ready to remount the pillar trim. I,ll get you a snapshot tomorrow when completed. There is a volvo v60 mold that seemed to fit well for another member in our forum. I spoted it once while shopping but never came across it again.
My pillar trim is grey and I almost sprung for that one as well.
Regardless it will require some grinding and trimming. Don't expect it to be perfect we are not ricer hoopties so to speak. HAR
Best, Gator
Old Jun 19, 2017 | 06:35 PM
Wow... that would be great... please post pics when done...
Old Jun 20, 2017 | 12:45 AM
sick430's Avatar
CLK Cabrio
yeah, can't wait to see it. It is definitely something I am interested in doing if I end up installing the supercharger.
Old Jun 20, 2017 | 11:15 AM
GatorMB's Avatar
I installed it this morning and it will need some detailing. There is a small gap in the upper part of the pod.
It is not easy but I wanted ample hand maneuverability while autocross with gloves. Also one must not create an extra blind spot. The Cabriolets are notorious for this.
Going to have to apply some heat to remove the gap this is a trial fit.
This is a trial fit and was really tight with the cables. Detailing the cables in a soldier formation will make installation easier.
The top is AEM A/F Center is EVO vac/boost and lower is EVO oil pressure Digital with LED color options.
Used a relay for gauge power and collected ignition power via the headlamp fuse box. I purchased a circuit breaker fuse with long blades and soldered the cable for relay coil. Next is a circuit breaker fuse for lighting up the EVO gauges.
This was my first pod install so the next one will be better without so much tweaking.
The pods are cheap enough so destroying one to learn is worth it. Get a heat gun and dremel. The rest is noise and fun.
Lot of overcast and rain so some photos are lousy with glare.
Here is an exterior shot for the trial fittment.
Smooth but needs tweaking
Best, Gator
Old Jun 20, 2017 | 06:17 PM
I went ahead and purchased 2 single pod with the adhesive back and put it near the left lower of the A Pillar and run the wiring inside a 1/4" wire loom. It look ok but I'm happy with it...
Attached Thumbnails W209 CLK55k BOOST gauge pod?-photo388.jpg   W209 CLK55k BOOST gauge pod?-photo87.jpg   W209 CLK55k BOOST gauge pod?-photo153.jpg   W209 CLK55k BOOST gauge pod?-photo828.jpg
Old Jun 21, 2017 | 12:16 PM
GatorMB's Avatar
I see you went with the EVO gauges as well. I liked the look.
That install made it real easy. My other thought was the dash mount which could be done with a Velcro strip in the center of the dash.
You did not have to damage anything either. but created a small blind spot maybe.
Best, Gator
Old Jun 21, 2017 | 06:15 PM
sick430's Avatar
CLK Cabrio
Nice work!!
Old Jun 23, 2017 | 11:00 AM
megacrazy's Avatar
CLK55 W209, CL63 W216
Don't forget 3D printing is viable option nowadays if you're looking for a perfect fit or can't find a pod specifically made for your car.
Old Jun 23, 2017 | 11:41 AM
Ahhh, I didnt thought about that... thanks
Old Jun 25, 2017 | 07:40 PM
GatorMB's Avatar
The 3-d Printing is easy for Mcrazy but for anyone considering the pillar mount.
Practice maneuvering the sun visor prior to committing pod position. I normally use my car at night and with the sun on my back in the daylight. Today had a frightful time putting the sunvisor in a safe driving position.
The EVO gauges are too strong at night and too weak in the day. Since they are LED some intensity resistor select might be needed. Have to collect the lighting resistance here and adjust accordingly.
VDO might be a better choice.
Cheers, Gator
Old Jun 25, 2017 | 11:48 PM
You're absolutely correct with the intensity light at night and lack of during the day!!!! Especially the red at night is too bright!!!
Old Jun 26, 2017 | 05:44 PM
GatorMB's Avatar
Thanks for the heads up, I was getting read to swap from blue to red at night.
The Blue is calm but bright. These gauges are nice but desperately need a day night configuration. Likely a resistor on the night side will lower and a low va transformer to make them brighter in the day.
just a hunch, Gator
Old Jun 26, 2017 | 05:57 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
We make these. You have to supply me with a OEM pillar mount
Old Jun 26, 2017 | 06:18 PM
GatorMB's Avatar
Hey Shardul,
I am a fan as I often frequent the W211 forums. That looks like more of a professional install than my first attempt.
You have to think W208/W209 has less real estate in the pillar/steering wheel for hard core driving. I like the look in the photo though just cannot convince myself that the clearance will be suitable. An E or S class no problem.
Thanks for chiming in and I may try one of yours when I get my gauges working good Day/night status.
Cheers, Gator
