245/35/18 front tires on w208 - yes it fits (for me)
Old Jul 24, 2017 | 11:07 AM
Dziner82's Avatar
99 C43 AMG, 2001 CLK55 AMG
hey all,
i know there is always lots of tire and wheel discussion (will it fit?), so i wanted to input my findings here.
i am able to run a Hankook Ventus V12 245/35/18 in the front on a 18x8" wheel. the wheel is TSW rockingham, offset is ET32
one I note is that i have the Kmac bushings and i run -2.5* of camber. having this camber allows the tire to clear the outside fender lip. if it was stock alignment settings i dont think it would clear the fender lip.
on the inside, there is clearance on the upper ball joint, but not much. that part does not move so its ok. but a higher offset wheel or taller or wider tire may cause issues there. so if you have a setup same as mine there is no clearance or rubbing issues! I have the H&R sport lowering springs and #5 front pads. without the lowering springs you will have more outside fender clearance and can probably run a more close to neutral camber setting.
245/35 is not a really common tire size, there is not a ton of choices, but its def an upgrade to the 225 fronts! 245/40 has many more options but thats a taller tire and may have clearance issues. also the 245/35/18 is very close to the 25" overall diameter that our cars are setup for.
im already looking into fender modifications for next racing season to run much wider in the front to offset the ton of front weight on this car.
dont really need much wider in the rear than 255s unless you have big power adders, if you want more traction just lower the rear pressures or get a sticky 200TW tire :-) but to each their own of course
sorry i dont have good photos showing the actual clearances. maybe i will get some next time i have the car out.
Old Jul 30, 2017 | 11:24 AM
Joe_Villar's Avatar
2002 CLK 55 AMG Convertible
245/35/18
I have 9" x 18 wheels on mine all around. I put the 245/35/18 in the front and it works. Mind you that being 9", the profile became even lower from the width of the rim. It fits but you have to be careful while driving on bad pavement.
Joe
Originally Posted by Dziner82
hey all,
Old Jul 30, 2017 | 06:24 PM
Dziner82's Avatar
Joe,
what is the offset of your wheels? Must be slightly higher than mine if you are fitting a 1" wider wheel in the front.
Old Aug 19, 2017 | 11:24 AM
BigJimmyLarge's Avatar
C204 C350 12
im running 245 40 18 on the front of my 208 55 and i get minor rubbing on full lock, stock height
