Steering play
Steering play likely ball joints or steering rag joint.
I have not inspected the motor mounts and the driveline couplings. I can see how those parts could cause vibration while driving but I don't think they would contribute to steering play that is evident with the wheels off the ground. The only test I have done on the ball joints is to look for play when twisting the tire at 12:00 and 6:00. I do not get any play at 12:00 and 6:00.
I think it is something funky with either the steering gear box or the steering coupler that connects the steering wheel to the gear box. With the gear box disconnected from the drag link I can wiggle the pitman arm. In certain positions of the steering wheel there is definitely a certain amount of play that is not present with the wheels pointing straight forward.
Never inspected the gearbox for play on any of my Benz. I have in the past adjusted the worm to sector shaft end play on domestic.
Never heard of a steering gearbox going bad on these cars.
To inspect ball joints jack the car up and place a stand under the spring area. have a buddy pry up on the bottom of tire thus showing ball joint play. I know mine are shot out.
Cheers
