Speed Senor for CLK 55
Old May 14, 2004 | 11:22 AM
bombay06's Avatar
CL 500
I am getting the Pioneer AVIC - N1 Installed into my CLK55... Where do I locate the speed sense wire??? Also what color is the wire?"
Old May 18, 2004 | 01:15 AM
MBConvert's Avatar
Speed pulse (sensor) wire is green with a black stripe. It can be found on the passenger side A-pillar. Remove the door sill (just pull it up) and remove the trim piece on the right hand side above the footwell (one screw in the middle under a small popout). You will find the wire (along with a hundred other wires) at the bottom of the car. It is connected to an 8-pin blue connector with a couple of other wires. You can splice into it anywhere.
Good luck, Chris.
Old May 18, 2004 | 11:37 AM
bombay06's Avatar
CL 500
Thank You
Old May 18, 2004 | 10:08 PM
MBConvert's Avatar
No problem. Please let us know how the installation goes.
