2004 CLK55 AMG high pressure A/C port
Old 06-28-2018, 08:25 PM
sksvlad's Avatar
2004 Mercedes CLK55 AMG
I found the low pressure port. Where is the high pressure port?
Old 06-28-2018, 08:29 PM
Plutoe's Avatar
Received 1,025 Likes on 953 Posts
1999 E300TD
Follow the other line and bla bla
sksvlad (06-29-2018)
Old 06-29-2018, 05:57 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
Not sure about the W209 CLK's, but my W208 has at least one of the ports in front of the radiator core support. Look up front and see what you find.
Old 07-02-2018, 05:35 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
Yep,
If you follow the mid size pipe from compressor to condenser. and liquid pipe from condenser to expansion valve the port will show up.
If you are using manifold gauges on the system make sure the high pressure valve is closed on them.
Cheers, Gator
Quick Reply: 2004 CLK55 AMG high pressure A/C port
