ExPert Advice Needed!!!
Old Nov 21, 2019 | 06:12 PM
quik55's Avatar
2000 ML55 AMG 2001 CLK55 AMG coupe 2002 CLK55 AMG Cabriolet 2025 BMW M2 6MT
Guys, as someone had said in one of my earlier posts, I probably shouldn't be working on my car myself, but things happen.
this is the passenger front spring perch, while attempting to remove the compressor after getting it stuck, I extended it into the perch unknowingly and bent up the inner ring to where it has detached on either side. It is at the very edge where the pad meets the perch.
looking for opinions... PLEASE!
and none like "man you're screwed you have to get a whole new perch" I'm hoping someone with experience can offer an opinion.
my main concern is that if left like this the hindered integrity of the punch and stress from the weight of the vehicle will cause the separations to open up more and more until its shot.
now I know a simple answer would be to just throw some welds on there and good as new. Unfortunately I've never welded and don't have a welder either.
therefore, my thought was to use a steel JB weld type product which would be better than nothing
PLEASE DOES ANYONE HAVE ANY ADVISE ON A JB STEEL WELD OR SIMILAR PRODUCT
that could help hold up the integrity.
im not sure if it would make sense to drill holes into the end of the separations on each side to stop them from spreading and then in weld or if that's the best answer overall or if it would make a difference.
hoping in reality, there's enough distribution of weight and force throughout the perch that something this small may not have an impact but out side advice would be great.
Thanks for any opinions or info on this!!!
Old Nov 21, 2019 | 06:27 PM
prktkljokr's Avatar
12 C200, 12 C180, 10 Fuso Warrior crew cab, 08 RTV ute, 05 Smart Fortwo cabrio, 09 Smart Fortwo
Im not a "Exert" but
Put it back together, then take it some where and get them to weld it up.
JB steel weld is only good for fixing a broken cast iron fence post spike and the like
Old Nov 21, 2019 | 06:43 PM
quik55's Avatar
Thanks so much for your reply, and that's what I was thinking. Shouldn't cost too much obviously.
Any other thoughts? Anyone think it'll just be fine ? Haha
what about opinions on drilling holes before I put it back and drive it to get it welded?
thanks
Old Nov 21, 2019 | 06:45 PM
prktkljokr's Avatar
thanks
No dont drill holes, you will just make it harder for the person who will do the repair
Old Nov 21, 2019 | 11:02 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
I wouldn't even worry about it. Put it back together and drive it. Re-check every so often until you are convinced it won't spread.
Old Nov 24, 2019 | 07:34 PM
Quant's Avatar
2002 CLK55
looks fine to me, but still worth getting welded.
