Offset Question
Offset Question
Hey guys! Will 18 x 8 1/2" with a 47 mm offset fit an 01 CLK 55?? Found a set of 4 AMG Monoblocks in this size with 235 40 18 tires all the way around. They would look better than the 17s that are on there, but I want to make sure they will fit. Thanks!
Thank You!
Thanks very much. I will save my cash for the proper set. I think I have determined that 32mm front and 37mm rear is the correct offset. Does that sound right??
There isnt a fixed offset that your car should use. It is because offset is not the only factor that determines whether the wheels will fit or not. Backspacing is also very important (especially if you plan to install Big Brakes in the future). Actually, the range could be between ET28-37. If you need any help as to which wheels will fit and which wont, please do not hesitate to shoot me an e-mail.
