W208 - Firewall Heat padding
Old May 3, 2023 | 07:28 AM
PHILLYCLSJOE's Avatar
2002 CLK55 AMG: 2004 S55 AMG: 2009 C63
Does anyone have any tips or tricks to redoing the Black firewall Heat/noise padding inside of the engine bay? Mine is coming apart at the top by the seal and im not sure what i can do about it other then replacing the whole thing. It doesn't look like it can be glued as the material has begun to break down. It's like a cloth mixed with a yarn type of material that seems difficult to work with.
Curious if anyone has had this problem in the past and found a good solution.
Thanks in Advance!
- Joe
Old Sep 29, 2023 | 08:14 AM
quik55's Avatar
2000 ML55 AMG 2001 CLK55 AMG coupe 2002 CLK55 AMG Cabriolet 2025 BMW M2 6MT
There’s a new updated design install is pretty easy did it a couple years ago already starting to get kinda degraded on passenger side by those two holes tho
