W209 lowering question
Old Apr 7, 2025 | 10:06 PM
Amgentleman55's Avatar
2003 Mercedes Clk 55 Amg
Hey, so I've got what could be a dumb question, will the stock 17in wheels that come on the 2003 55 fit if I install bilstein B8 and h&r lowering springs? Or will I need spacers? I read that coilovers required spacers to clear on the stockies.
Old Apr 8, 2025 | 11:30 AM
Robjr's Avatar
Veteran: Army
2005 Mercedes Benz C55 AMG..1967 Lotus Europa..1987 Lotus Turbo Esprit HCI..2020 Mercedes Benz E350
Amg.......
You may want to compare the height of your oem struts/shocks with the Bilsteins B8. You will find the B8 are approx. 1/2" shorter than OEM measurements. I installed B6's four years ago and they were 1/2" shorter than my oem's.
Let this forum know what you find........
Good luck....
Rob
Old Apr 9, 2025 | 09:12 PM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
If I am reading your post correctly you are asking if the stock wheels you have now will work if you lower the vehicle? That answer is yes. The rotating mass of the wheel will not change when you lower; caliper clearance will remain the same.
John
Old Apr 9, 2025 | 10:20 PM
Yea I was just thinking about the wheel offset being to high. The coilover guys seemed to have issues and needing spacers, I'll be installing the new stuff soon.
thanks
Old Jul 16, 2025 | 08:51 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
thanks
I had flush 18"s on mine with coil overs and it was fine.
Old Jul 16, 2025 | 09:02 AM
Yea I ended up lowering it on bilstein shocks and h&r springs with 18ins. Looks pretty nice now.
Old Jul 16, 2025 | 07:15 PM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
My assumption would be that the aftermarket springs will have the same diameter as the OEM ones. If that is the case, I see no reason why the springs would not clear the wheels.
I also reason no reason why the Bilstein shock towers would not clear either.
