W208 CLK55 differential woes
Old Nov 14, 2025 | 03:08 PM
quik55's Avatar
2000 ML55 AMG 2001 CLK55 AMG coupe 2002 CLK55 AMG Cabriolet 2025 BMW M2 6MT
Hey yall.. been making my way down the w208 CLK55 differential rabbit hole for a while now.. after a pinion seal replacement or after 210k miles the rear diff is tired and whiney.. plan was to pick up a used one and rebuild my old with a quaife.. well after a few years I found one!! I swapped it in and decided to drive it before putting in new fluid 😂😂
as you may know these things are literally impossible to find..
needless to say @ governor the old fluid either boiled or something happened and most of it escaped out of the breather and blowing out pinion seal. Drove it about 3 miles home..
now there’s a bunch of play up/down in and out in the pinion.. looks like this one will be getting the rebuild service..
I’ve never cracked open a diff..curious what anyone thinks.. If it’s even able to be fixed!!
anyone have a lead on a quaife?
thanks boys
File Type: mov
File Type: mov
