CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Suspension adjustments in manual
Old May 3, 2009 | 11:01 PM
spr's Avatar
spr
Can someone please scan the section on adjusting the suspension in the manual, including what the stock settings are etc.?
Thanks. Sean
Old May 4, 2009 | 11:00 AM
TTMotorsports's Avatar
Former Vendor of MBWorld
Whatever we're tuning!
Turn clockwise top and bottom adjustments until they stop and then reverse and count how many full turns until stop.
Divide by 2 and use this setting as your "stock" setting. The setting from the factory is very soft especially in the rear.
Depending on where you are planning on driving, setting the car up with the firmest settings at all 4 corners is actually quite good. Helps to mitigate the "bouncy" rear.
Also what we have found that has helped the suspension and getting the strut setting is scaling the car and give it a really good balancing. It will make a HUGE difference!
Also if you are running stock wheels and tires bump the pressure in the tires up 2-4lbs. Helps to tighten the sidewall a bit.
Old May 4, 2009 | 10:43 PM
spr's Avatar
spr
Cool. Does it say anything about the stock ride height and/or camber settings? Thanks. Sean
Old May 5, 2009 | 11:02 AM
If you balance the car that will help set your ride height.
Depending on how you are going to drive the car(street, strip, road course) should dictate your camber set up.
My information is derived from experience building and working on a few of these street legal race cars that really belong on the track!.
Old May 5, 2009 | 04:08 PM
spr's Avatar
spr
I always corner balance my cars for the appropriate cross weights. However to do so I would like the ideal camber settings since they're ride height dependent.
