CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Tires - PSI
Old May 11, 2009 | 09:02 PM
Frankster's Avatar
Tires - PSI
One of my tires were low today, so I decided to look at the manufacturer specs by the driver's side door sill. I was taken aback with the #s: 48psi fronts / 44 psi rears...anyone else noticed this and whether or not you guys are following MB's recommendation? That's the highest I've ever seen.
Old May 11, 2009 | 10:44 PM
DFW01E55's Avatar
'14 ML BT
Crazy stuff huh?
I'm at 42 for the street.
Old May 11, 2009 | 11:04 PM
johno530's Avatar
'08 CLK Black, '08 SL65, '17 SL65, '07 SL55, '20 E63S Wagon, '22 E450 All Terrain
Inside the gas filler cover the chart says 38/33 psi for up to 155 mph
Old May 31, 2009 | 08:36 AM
LOVEMYBS's Avatar
10 Cayenne GTS, 07 Porsche 911 Turbo
Same question, I reset my pressure to 38/33 but you're right, the recommended pressure inside the door is 48/44, the gas tank is 38/33 up to 155mph and 48/44 up to 186. The owners manual says 38/33.
Old May 31, 2009 | 11:27 PM
ET550's Avatar
2008 CLK 63 Black Series, 2013 G63, 2014 RS5 Coupe, 2013 JKUR 10A
48/44 is overkill for the street especially if you are using the car as a DD. the 38/33 recommendation will give you the most comfortable ride without sacrificing too much handling. I have been using 42/38 as a compromise for daily driving as I find it results in a little bit better handling without sacrificing too much ride comfort. I would recommend starting with the 38/33 for a little while and then experiment upwards and see if you feel a difference.
Old Jun 1, 2009 | 02:34 PM
spr's Avatar
spr
Why do you guys run so much pressure front?? Is it because of the larger tire widths? If you say weight distribution, isn't it close to 50/50? Also although turn in, is I am sure better, doesn't it get wayy to greasy with that much pressure when on track? I've never heard of such high pressure. I do remember that the clk63 regular runs this much with the smaller tires. Why?
