CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Evosport | New Lightweight 2-Piece Front & Rear Rotors for CLK63 Black Series
Old Feb 23, 2010 | 12:41 AM
Simon @ evosport's Avatar
PREMIER SPONSOR
SHAVES 26-LBS UNSPRUNG WEIGHT!
Designed as a direct brake rotor replacement for the OE 2-piece front and 1-piece rear brake rotors. No modifications are necessary. The Evosport rotors will bolt directly to the car and work with OE AMG brake calipers. Not only will the upgraded multi-piece "floating" rotor design help mitigate brake fade, but are lighter than stock and reduce unsprung weight by 26-lbs. on all four corners! This means better acceleration, braking and cornering. In addition, you get to maintain the AMG calipers without going to a more expensive solution that requires replacing them.
Drilled and slotted to match the OE rotors, hats are lightweight aluminum and black hard anodized. And unlike the stock rotors that only vent correct on one side (or have universal venting), the Evosport rotors have a Right and Left application for proper venting of the disc and chaneling of airflow.
Benefits:
  • Direct bolt-on design requires no modification
  • Works with OE AMG calipers
  • Lightweight design (26-lbs unsprung weight savings over stock!)
  • Aluminum hat, hard anodized (Black)
  • Better value and cost of ownership over OE! The OE 2-piece 360mm rotor sells for $990 EACH!
  • Unique Left/Right application for proper venting/airflow (unlike OE)
  • Replaceable discs and hardware
  • Better heat dissipation and less brake fade
  • Improved acceleration, braking and cornering with less unsprung weight!
Includes Front and Rear rotors with black anodized hats (Front or Rear pairs can also be purchased separately). For more information or to order, CLICK HERE.
Please feel free to call or email us with any questions.
Anthracite anodized hats shown below. Actual rotors have black anodize:
Evosport 2-Piece Rotor Installed on SL63 AMG (Note: Right-Side Rotor Shown):
Old Feb 23, 2010 | 01:24 AM
Auraraptor's Avatar
Simon...my SL has old the factory 8 piston caliper with solid front disk.
Do you still sell the lightweight front disk replacement for it?
What are its dimensions? 360 x 32mm?
How much?
Thanks much
Old Feb 23, 2010 | 01:48 AM
PREMIER SPONSOR
How much?
Thanks much
Yes. Just PM'd you.
Old Feb 23, 2010 | 01:53 AM
hyper_tune77's Avatar
2006 mercedes benz C180k Avantgarde SE
The price for the front rotors is not available on your website.
Zack
Old Feb 23, 2010 | 01:56 AM
PREMIER SPONSOR
Zack
Correct, sorry it's not up yet. Should be online tomorrow. Price is $1,299/pair.
Old Feb 23, 2010 | 12:12 PM
mk4mike's Avatar
Sold - CLK500
in terms of weight how do these compare to the brembo 6 piston gt kit? would they fit a non bs?
im interested in both front and rear weight savings.
Old Feb 23, 2010 | 01:24 PM
PREMIER SPONSOR
I don't know off the top of my head how they compare to the Brembo.
When you say "non bs", do you mean a standard CLK63? If so, then yes they will fit.
Old Feb 26, 2010 | 04:02 PM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
Simon, I'm already running your rear 2-piece rotors on my BS, how much lighter are the evosport fronts than the stock OEM 2-piece units?
Old Feb 26, 2010 | 05:27 PM
PREMIER SPONSOR
Jim, they're 12-lbs lighter (total front axle). Ours also cool/vent more effectively than the stock OE 2-piece.
Old Feb 27, 2010 | 12:40 PM
GeoGeo's Avatar
CLK BS
Simon,
These look great! Any track experience with the full set?
Old Feb 27, 2010 | 12:57 PM
PREMIER SPONSOR
Originally Posted by GeoGeo
Simon,
Plenty of time with the 55's but we just released the 63's so not yet, although we've run the rears hard. I'm sure there will be plenty of people posting track experience with 63's and our rotors soon enough!
Old Jun 23, 2010 | 04:01 AM
hami's Avatar
CLK55 '05 CLK320 '02
would these by any chance fit into a W209 CLK55?
Old Jun 24, 2010 | 01:16 PM
otoupalik's Avatar
MBWorld Founder
Sorry, they will not.
Old Jun 25, 2010 | 03:21 AM
hami's Avatar
well do they make any rotors that would?
Old Jun 29, 2010 | 11:24 AM
brad @ evosport's Avatar
PREMIER SPONSOR
None fast enough!
Sorry, we do not at this time.
