CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
What is the minimum spec for rotor thickness?
Old Jun 13, 2011 | 02:30 PM
wonsuk_utmb's Avatar
2012 ML350 Bluetec
Does anyone have the actual numbers. Thanks.
Old Jun 13, 2011 | 03:37 PM
buffyclk500's Avatar
clk500
If u need them cut some shops don't cut Benz rotors
Old Jun 13, 2011 | 03:43 PM
2012 ML350 Bluetec
They are pretty smooth. I was needing the number to decide if I was going to just replace the pads or the pad and rotors. I had an Audi RS4 and the stealer pulled a fast one on me by saying both the rotors and pads needed replacing when the rotors were still within spec, and I didn't want that to happen again so having the number to measure would be helpful.
Old Jun 14, 2011 | 01:05 AM
BerBer63's Avatar
2009 C63
sometimes its listed on the edge of the rotor...take the wheel off and look closely
Old Jun 14, 2011 | 01:14 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I checked the WIS but it doesn't have the CLK63 BS (at least my copy doesn't)
Pull off the wheel and check the rotor hat, it should state it on the outer rim
I posted a pic in this thread (post #8):
https://mbworld.org/forums/w210-amg/...-our-cars.html
Mine is 30.4mm (later changed to 29.4mm)
