CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Suspension Adjustments
Old Sep 28, 2012 | 11:03 AM
mellowyellow's Avatar
AMG GT C Roadster
I read thru the manual for suspension adjustment, and if I am only adjusting ride height, is it a pretty easy DIY with the KW setup? I will not be touching rebound settings, etc.
Old Sep 28, 2012 | 02:39 PM
sprins's Avatar
G55, SLS, smart eq
Can you adjust the height on the CLK63 BS? I thought only the damping settings.
Old Oct 4, 2012 | 04:20 PM
AMG GT C Roadster
Yep, pretty much everything is adjustable on the BS, it's a really sweet KW suspension.
So no one has done a height adjustment themselves?
Old Oct 6, 2012 | 01:04 AM
DFW01E55's Avatar
'14 ML BT
There are collars that set the ride height, they have 3 (IIRC) screws on them that drive into the column itself.
Take the weight off the wheel, then back out the 3 screws and spin the collar down to your preferred height (derived form your knowledge of suspension settings) and then tighten the 3 screws into the collar.
Do a search on suspension/geo settings before messing with it though, there is some detail available.
My local MB dealer insisted they couldn't do it (according to specs I provided), then I got the car back and it was done. Except that the 3 screws were destroyed for future use.
Nice touch.
I always adjusted the damp/rebound at home for the different tracks I would run.
Old Oct 10, 2012 | 02:28 PM
AMG GT C Roadster
I made the adjustments I wanted last night. There is only 1 set screw that you need to back out two turns, and the spin collar tool is easy to use.
One major thing is to blow compressed air on the threads before you wind anything up or down.
