CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Car is starting to get twitchy at high speed...
Old Mar 11, 2013 | 06:20 PM
MACHC5's Avatar
Veteran: Army
CLK63 Black, E350 Wagon, Supercharged Denali, Lotus Elise, Tesla Model 3 Dual-Motor.
Has anyone else's car started to get twitchy when hammering it up to 125mph?
I don't know if it's the shocks or alignment has changed some.
MachC5
Old Mar 11, 2013 | 07:07 PM
ecampbell's Avatar
2008 BS
You might have thrown a wheel weight.
Old Mar 11, 2013 | 07:17 PM
Jim Brady's Avatar
'22 G 63 AMG, '21 GLE 53 AMG, '20 NSX
Check for leaking shock. I had a twichy feeling at the track sometime ago and it turned out to be a rear shock leaking.
Old Mar 11, 2013 | 09:26 PM
MACHC5's Avatar
Veteran: Army
I'll check the shocks out and the wheel balance.
Thanks for the suggestions...
It seems almost like the old 911's used to act.
Old Mar 12, 2013 | 05:54 PM
Eitan's Avatar
CLk Black
Where is the twitchy feeling? Rear or Front? Have you checked to see the condition of your tires? Also bushings may be the culprate if its in the front.....
Old Mar 12, 2013 | 09:20 PM
Vic55's Avatar
Administrator
Did you change the rear tires only? You might have a contact patch adjustment....
Old Mar 13, 2013 | 07:12 AM
MACHC5's Avatar
Veteran: Army
Guys -
When flooring it I've got to try not to move the wheel.
If I do, I've got to chase after it to the left and right.
The tires are new MPSS 265 Ft. 295 Rr 19".
Old Mar 13, 2013 | 09:59 AM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
Check you bushings, they wear out pretty quickly due to the ridgid chassis and suspension set-up.
Weistec developed Delrin bushings to address the issue.
https://mbworld.org/forums/clk63-bla...-bushings.html
